1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 80 MHz version of uCDIMM ColdFire 5282
To: "K.M Ha" <[email protected]>
Cc: [email protected]
Date: Mon, 9 Jun 2008 09:38:52 -0500
I have a question to those using the 80 MHz version of the ColdFire uCDIMM 5282. How do you connect this to external logic such as an FPGA? Here's the bus timing section of the data sheet:
Attachment: pastedGraphic.pdf
Description: Adobe PDF document
This implies that external logic must assert TA within 2.5 ns (Time B0 minus time B1a) of the rising edge of CLKOUT. WIth the 64 MHz part this requirement was 5.625 ns, which wasn't easy to reach, but was possible.
Do you do some tricky stuff like use the falling edge of CLKOUT to clock the section of the FPGA that drives the ColdFire TA* pin?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
uC5282 based RTEMS FlashSize error K.M Ha
Prev: Re: uC5282 based RTEMS FlashSize error Eric Norum
Next: RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
