1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 80 MHz version of uCDIMM ColdFire 5282
To: "'Eric Norum'" <[email protected]>
Cc: [email protected]
Date: Tue, 10 Jun 2008 00:13:03 +0900
I started uC5282 80 MHz testing from today.
So, i am just testing RAM based and Flash based  booting.
After that i will try to bus interface with external chipset (e.g CPLD).
Changed flag options from your comment;
ARCH_DEP_LDFLAGS += -Wl,'--defsym' -Wl,'_FlashSize=16M'
Compiles were OK,
But, flash booting was fault with below error messages;
B$ tftp
uCTFTP Console 1.0 is running ...
done
B$ program
erase...    done
write...    done
B$ go
Copy...access fault
PC[0x48082700] SSP[0x0001fe48]    BootstrapSP[0x0001fff0]
    D0       D1       D2       D3       D4       D5       D6       D7
0x0003ffff 0x0003fffe 0x00040000 0x00000000 0x0000d50a 0x00000001 0x0001ff44
0x00000000
    A0       A1       A2       A3       A4       A5       A6
0x00020000 0x01000001 0x0001ff44 0x0000b1c6 0x0001ff44 0x00012310 0x0001ffa4
RAM booting is worked.
B$ goram
Go from RAM!
Go from 0x40000
Welcome to RTEMS GeSys
This system $Name: GeSys_2_4 $ was built on 20080609KST23:58:02
$Id: init.c,v 1.43 2008/03/22 20:36:13 guest Exp $
Installing TIOCGWINSZ line discipline: ok.
To skip initialization, press a key now...
No ifcfg argument; using 1st interface after loopback...
Configuring 'fs1' from boot environment parameters...
fs1 141.223.48.203/255.255.255.0
gateway: 141.223.48.99
hostname: Linac00:BI38
fs1: Ethernet address: 00:06:3b:00:ad:b8
This is RTEMS-RPCIOD Release $Name: R_rtems_nfs_1_7 $
($Id: rpcio.c,v 1.44 2008/04/29 15:49:05 strauman Exp $)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release $Name: R_rtems_nfs_1_7 $
($Id: nfs.c,v 1.49 2008/04/24 21:45:04 guest Exp $)
Do you have a any ideas for solve flash booting?
Kiman,
-----Original Message-----
Sent: Monday, June 09, 2008 11:39 PM
To: K.M Ha
Subject: 80 MHz version of uCDIMM ColdFire 5282
I have a question to those using the 80 MHz version of the ColdFire uCDIMM
5282.  How do you connect this to external logic such as an FPGA?  Here's
the bus timing section of the data sheet:
uC5282 based RTEMS FlashSize error K.M Ha
80 MHz version of uCDIMM ColdFire 5282 Eric Norum
Prev: 80 MHz version of uCDIMM ColdFire 5282 Eric Norum
Next: How to Upgrade Epics R3.13 device driver to Epics R3.14 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
