Hi Eric,
>>Do you have this value in the ColdFire environment?
>>_0=10000000:400000:RW
Default value is configured by Arcture company like this;
_0=10000000:100000:RW
And changed value to _0=10000000:400000:RW After rebooting the Coldfire and
tried to flash burning.
Yes, Now successfuly booting and worked!!!
Thank you for a tough advice and help!!!!!
Now i can go ahead to my application.
B$ printenv
FACTORY=Arcturus Networks Inc.
REVISION=uC5282 Rev 1.1 16MB External Flash
SERIAL=X4747379F-01DB8
CONSOLE=ttyS0
KERNEL=0:linux.bin
KERNEL_ARGS=root=/dev/mtdblock0 quiet
HWADDR0=00:06:3B:00:AD:B8
FW_VERSION=010808004
RAMIMAGE=yes
CACHE=on
NETMASK=255.255.255.0
NAMESERVER=141.223.1.2
GATEWAY=141.223.48.99
HOSTNAME=Linac00:BI38
NTPSERVER=141.223.182.106
AUTOBOOT=3
IPADDR0=141.223.48.203
[email protected]:/home/hkm:/home
CMDLINE=/home/work/pad_base-3.14.8.2/st.cmd
INIT=141.223.48.202:/home/hkm:work/st.sys
B$
B$ go
Copy...done
go! 0x40000
Welcome to RTEMS GeSys
This system $Name: GeSys_2_4 $ was built on 20080609KST23:58:02
$Id: init.c,v 1.43 2008/03/22 20:36:13 guest Exp $ Installing TIOCGWINSZ
line discipline: ok.
To skip initialization, press a key now...
No ifcfg argument; using 1st interface after loopback...
Configuring 'fs1' from boot environment parameters...
fs1 141.223.48.203/255.255.255.0
gateway: 141.223.48.99
hostname: Linac00:BI38
fs1: Ethernet address: 00:06:3b:00:ad:b8 This is RTEMS-RPCIOD Release $Name:
R_rtems_nfs_1_7 $
($Id: rpcio.c,v 1.44 2008/04/29 15:49:05 strauman Exp $)
# Use DMA timer 0 (DMA timer = 0x10, add timer #)
#uC5282WatchdogType = 0x10
# Start watchdog with priority 20
#wdStart(20)
Type 'cexpsh.help()' for help (no quotes)
Cexp>
Kiman Ha,
- registering IOC shell functions Matthew Pearson
- uC5282 based RTEMS FlashSize error K.M Ha
- 80 MHz version of uCDIMM ColdFire 5282 Eric Norum
- RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
Re: How to Upgrade Epics R3.13 device driver to Epics R3.14 Eric Norum
<2008>
2025
<2008>
2025
