> The error code listed in the task list, means S_objLib_OBJ_UNAVAILABLE
This is probably supporting evidence for problems with an invalid semaphore
id.
> 231ff8 vxTaskEntry +68 : 1ea3ad00 ()
> 1ea3ad70 epicsThreadPrivateGet+f8 : 1ea2c94c ()
> 1ea2c94c epicsThreadCallEntryPoint+444: __cp_exception_info ()
> 162680 __cp_exception_info+0 : __default_unexpected(void) ()
> 16263c set_terminate(void (*)(void))+0 : terminate(void) ()
> 16262c __default_unexpected(void)+0 : cplusTerminate(void) ()
> 153c50 cplusTerminate(void)+50 : taskSuspend ()
This confirms that the epicsThread last chance exception catch ran, and that
it called the unexpected exception handler.
> I noticed that there are two more pending timerQueue tasks, which might
> explain why everything still works.
When independent prioritized execution of timers is needed then independent
timer queue threads are used. So its normal to have more than one timer
queue thread, but it is almost certainly also true that if one of them dies
that you have lost some important component of the system.
Since the timer queue class has proper coordinated shutdown of its thread in
its destructor I expect that the only way that its event semaphore id could
be seen by its thread to be invalid would be if another thread (or one of
its timer callbacks) maliciously stomped on it.
One way of debugging such situations is to set a break point for when there
is a write to the memory location where the semaphore id is stored (vxWorks
supports this special type of break points if your processor supports "break
on address access"). It will be tricky to learn the proper address when
debugging in the target shell so I would recommend building the system for
debugging and attaching with the source code debugger to the system.
If you processor doesn't support "break on address access" features then you
can also try suspending some of the threads in the system until you figure
out which thread is the culprit. I like a divide and conquer approach (i.e.
suspending half of the threads, and then half again of what remain until you
have found the guilty thread). Of course it always helps to turn up the
knobs that cause the problem to be reproduced more quickly. Usually this is
done by artificially increasing processing or interrupt rates until nearly
all of the CPU is used.
Jeff
> -----Original Message-----
> From: Matthew Pearson [mailto:[email protected]]
> Sent: Friday, June 20, 2008 5:31 AM
> To: Jeff Hill
> Cc: 'Andrew Johnson'; [email protected]
> Subject: RE: unhandled exception in timerQueue
> Hi,
> Sorry for the delay in responding, first beam got in the way...
> The stack trace for the suspended process is:
> the task information is:
> NAME ENTRY TID PRI STATUS PC SP ERRNO
> DELAY
> timerQueue 1ea3ad00 1e0ab530 148 SUSPEND 22bbf4 1e0ab090
> 3d0002 0
> stack: base 0x1e0ab530 end 0x1e0a8650 size 11712 high 3184 margin
> 8528
> options: 0xc
> VX_DEALLOC_STACK VX_FP_TASK
> VxWorks Events
> Events Pended on : Not Pended
> Received Events : 0x0
> Options : N/A
> r0 = 6acfc1 sp = 1e0ab090 r2 = 0 r3 =
> 0
> r4 = 1e0ab0a0 r5 = 1e0aafa0 r6 = 1e0ab030 r7 =
> 1e0aaf90
> r8 = 1e0ab020 r9 = 2bfc8f3b r10 = 1ea725f0 r11 =
> 43300000
> r12 = 1eb27ed0 r13 = 0 r14 = 0 r15 =
> 0
> r16 = 0 r17 = 0 r18 = 0 r19 =
> 0
> r20 = 0 r21 = 0 r22 = 0 r23 =
> 0
> r24 = 0 r25 = 0 r26 = 1ea7a5b8 r27 =
> 1ea330dc
> r28 = 1ea48068 r29 = 1ea324ac r30 = 1e0ab530 r31 =
> 1e0ab530
> msr = b030 lr = 1ea484ec ctr = 19ac34 pc =
> 22bbf4
> cr = 20000049 xer = 0
> fpcsr = b2002100
> fr0 = 0 fr1 = 0 fr2 = NaN fr3 =
> NaN
> fr4 = NaN fr5 = NaN fr6 = NaN fr7 =
> 0
> fr8 = 0 fr9 = 0 fr10 = 0 fr11 =
> 0
> fr12 = 0 fr13 = 4.5036e+15 fr14 = NaN fr15 =
> NaN
> fr16 = NaN fr17 = NaN fr18 = NaN fr19 =
> NaN
> fr20 = NaN fr21 = NaN fr22 = NaN fr23 =
> NaN
> fr24 = NaN fr25 = NaN fr26 = NaN fr27 =
> NaN
> fr28 = NaN fr29 = NaN fr30 = NaN fr31 =
> NaN
> On Tue, 2008-06-17 at 09:31 -0600, Jeff Hill wrote:
> > Hello Mathew,
> > My best guess (subject to change of course :-) is that some tangential
> code
> > is corrupting the semaphore id used by a timer queue thread.
> > > epicsThread: Unexpected C++ exception "epicsEvent::invalidSemaphore()"
> > This is coming from the last chance exception handler in the epicsThread
> > class. It is not a message from the dreaded unexpected exception handler
> in
> > the CRTL (associated with violated exception specifications). I will fix
> the
> > message emitted by epicsThread so that this is clear in the future.
> > > > interrupt: Main interrupt with no cause
> > This output might be supporting evidence for the corruption theory.
> > Please try also the vxWorks shell "tt" command for the suspended thread.
> > That may, or may not, provide some useful information.
> > Jeff
> > > From: [email protected] [mailto:tech-talk-
> [email protected]]
> > > On Behalf Of Matthew Pearson
> > > Sent: Tuesday, June 17, 2008 6:52 AM
> > > To: Andrew Johnson
> > > Cc: [email protected]
> > > Subject: Re: unhandled exception in timerQueue
> > > Update:
> > > I've just seen the same again (after a reboot, and a couple of
> hours)...
> > > but the IOC shell is fine.
> > > 0x1e0ab530 (timerQueue): Unhandled C++ exception resulted in call to
> > > terminate
> > > with type "Q210epicsEvent16invalidSemaphore" in thread "timerQueue" at
> > > TUE JUN 17 2008 11:50:26.620275542
> > > I also see:
> > > 3d0002 0
> > > Regards,
> > > Matthew
> > > On Tue, 2008-06-17 at 13:46 +0100, Matthew Pearson wrote:
> > > > Hi Andrew / Tech-Talk,
> > > > I've just seen the following printout in my vxWorks IOC shell (EPICS
> > > > 3.14.8.2):
> > > > 0x1e0abd20 (timerQueue): Unhandled C++ exception resulted in call to
> > > > terminate
> at
> > > > FRI JUN 13 2008 16:51:01.488894248
> > > > 0x1e03e550 (timerQueue): Unhandled C++ exception resulted in call to
> > > > terminate
> at
> > > > FRI JUN 13 2008 16:56:38.279153464
> > > > It looks like an Q210epicsEvent16invalidSemaphore exception is
thrown
> > > > from an epicsThread. But this seems to be unexpected, and
> unexpected()
> > > > is called, which seems to exit the IOC shell.
> > > > Nick Rees suspects that this was discussed a while ago, and may have
> > > > been dealt with in a later version than 3.14.8.2. Any ideas?
> > > > Regards,
> > > > Matthew Pearson
> > > > DLS Controls
> > > <DIV><FONT size="1" color="gray">This e-mail and any attachments may
> > > contain confidential, copyright and or privileged material, and are
for
> > the
> > > use of the intended addressee only. If you are not the intended
> addressee
> > > or an authorised recipient of the addressee please notify us of
receipt
> by
> > > returning the e-mail and do not use, copy, retain, distribute or
> disclose
> > > the information in or attached to the e-mail.
> > > Any opinions expressed within this e-mail are those of the individual
> and
> > > not necessarily of Diamond Light Source Ltd.
> > > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > > attachments are free from viruses and we cannot accept liability for
> any
> > > damage which you may sustain as a result of software viruses which may
> be
> > > transmitted in or with the message.
> > > Diamond Light Source Limited (company no. 4375679). Registered in
> England
> > > and Wales with its registered office at Diamond House, Harwell Science
> and
> > > Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> > > </FONT></DIV>
> contain confidential, copyright and or privileged material, and are for
the
> use of the intended addressee only. If you are not the intended addressee
> or an authorised recipient of the addressee please notify us of receipt by
> returning the e-mail and do not use, copy, retain, distribute or disclose
> Any opinions expressed within this e-mail are those of the individual and
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> </FONT></DIV>
- Re: camonitor prints CA errors to stdout rather than stderr J. Lewis Muir
- Re: camonitor prints CA errors to stdout rather than stderr Andrew Johnson
- unhandled exception in timerQueue Matthew Pearson
- Re: unhandled exception in timerQueue Matthew Pearson
- RE: unhandled exception in timerQueue Jeff Hill
- RE: unhandled exception in timerQueue Matthew Pearson
EDM Freezing On Linux David Wetherholt
<2008>
asyn problem John Sinclair
<2008>
