On 7/17/08 9:31 AM, Mark Rivers wrote:
> I’ve done some more investigation of this. It appears that stdout is
> being closed and re-opened when the vxWorks startup script completes.
> Does anyone know if this is true? If so, I don’t understand why. I
> can understand why stdin may be reopened, changing from the startup
> script to the console. But why stdout? Is there a way to open a file
> descriptor to the console that will not be closed and re-opened when the
> startup script completes?
Hi, Mark.
I looked at src/iocsh/iocsh.cpp in EPICS base 3.14.9 and it seems to be
doing some special things with (FILE *) references to support
redirection. Maybe this is causing the problem? The comment in the
file indicates the original author was Marty Kraimer and that it was
modified by Eric Norum a little later.
There are about four places in the file where fclose() is called on a
(FILE *) reference. You could add a print statement before these to see
if this is indeed where stdout is getting closed.
But I bet Marty or Eric know better.
Lewis
> *From:* Mark Rivers
> *Sent:* Wednesday, July 16, 2008 7:07 PM
> *To:* EPICS tech-talk
> *Subject:* stdout being changed in EPICS
> Folks,
> I have run into a problem with the value of stdout being changed some
> time after iocInit is called. This is happening at least on vxWorks, I
> have not checked other platforms.
> This is a real problem, because I have a vendor library that assigns a
> file descriptor to the value of stdout before iocInit is run, and then
> does fprintf() to that file descriptor for logging purposes. This works
> fine until just after iocInit is called, at which point that file
> descriptor is invalid (fprintf returns an error), and the value of
> stdout has changed to a new value.
> One can easily reproduce this problem with the example application that
> EPICS base generates. I just added this small global function
> show_stdout() to the end of devXxxSoft.c
> corvette> tail devXxxSoft.c
> /*If return was succesful then set undefined false*/
> if(!status) pxxx->udf = FALSE;
> return(0);
> int show_stdout()
> printf("stdout=%p\n", stdout);
> return(0);
> Here is what I see at the end of the st.cmd file, to which I added calls
> to show_stdout just before and after iocInit:
> show_stdout
> stdout=0x1d0e290
> value = 0 = 0x0
> iocInit()
> Starting iocInit
> ### EPICS IOC CORE built on Jun 9 2008
> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> iocInit: All initialization complete
> value = 0 = 0x0
> show_stdout
> stdout=0x1d0e290
> value = 0 = 0x0
> ## Start any sequence programs
> seq &sncExample,"user=epics"
> SEQ Version 2.0.11: Mon Jun 9 16:03:45 2008
> Spawning state program "sncExample", thread 0x1c2e7c0: "sncExample"
> value = 29550528 = 0x1c2e7c0
> Done executing startup script
> /home/epics/devel/example/iocBoot/iocexample/st.cmd
> iocexample> show_stdout
> stdout=0x1ffe738
> value = 0 = 0x0
> Note that the value of stdout is 0x1d0e290 before the call to iocInit,
> and just after iocInit returns. However, the value has changed to
> 0x1ffe738 when I type the show_stdout command manually a few seconds
> after I get the vxWorks prompt. This happens whether or not the SNL
> program is run (comment out the seq call).
> Does anyone know why the value of stdout is changing? It is a real
> problem for software that uses the value of stdout through a call to
> iocInit.
> Thanks,
> Mark
- Re: stdout being changed in EPICS Eric Norum
- RE: stdout being changed in EPICS Mark Rivers
RE: Building 32-bit EPICS binaries on 64-bit Linux systems Allison, Stephanie
<2008>
2025
<2008>
2025
