1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stdout being changed in EPICS
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Thu, 17 Jul 2008 18:30:19 -0500
On Jul 17, 2008, at 5:25 PM, J. Lewis Muir wrote:
On 7/17/08 9:31 AM, Mark Rivers wrote:
I’ve done some more investigation of this. It appears that stdout is
being closed and re-opened when the vxWorks startup script completes.
Does anyone know if this is true? If so, I don’t understand why. I
can understand why stdin may be reopened, changing from the startup
script to the console. But why stdout? Is there a way to open a file
descriptor to the console that will not be closed and re-opened when the
startup script completes?
Hi, Mark.
I looked at src/iocsh/iocsh.cpp in EPICS base 3.14.9 and it seems to be
doing some special things with (FILE *) references to support
redirection. Maybe this is causing the problem? The comment in the
file indicates the original author was Marty Kraimer and that it was
modified by Eric Norum a little later.
Not an issue. Mark isn't using iocsh.
There are about four places in the file where fclose() is called on a
(FILE *) reference. You could add a print statement before these to see
if this is indeed where stdout is getting closed.
But I bet Marty or Eric know better.
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
RE: stdout being changed in EPICS Mark Rivers
Re: stdout being changed in EPICS J. Lewis Muir
Prev: Re: stdout being changed in EPICS J. Lewis Muir
Next: array calc / inverse subarray survey? Rowland, J (James)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: VXI resource manger converted to R3.14? Nicholas P. DiMonte
