1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: array calc / inverse subarray survey?
To: <[email protected]>
Date: Fri, 18 Jul 2008 12:12:55 +0100
Hi
I’d like to do some array calculations (FFT, rectangular to polar, filtering etc). I’d like the option to run at high rates (KHz) which would suggest using asyn. Is there any standard for this? Some possibilities are aCalcout, waveProc, genSub. If the waveform record had an input and an output I could easily put the calculations in the asyn layer but I can’t see an obvious way to build a processing chain with only one link. Any suggestions?
Also is there a standard for inverse subarray? I’d like to combine 100s of scalar PVs into one waveform.
Thanks
James
Senior Software Engineer
Diamond Light Source
RE: array calc / inverse subarray survey? Mark Rivers
Re: array calc / inverse subarray survey? Luedeke Andreas
Prev: Re: stdout being changed in EPICS Eric Norum
Next: MAXv problem update EPICS record jerome HOSSELET
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Next: RE: array calc / inverse subarray survey? Mark Rivers
