1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: array calc / inverse subarray survey?
To: "Rowland, J (James)" <[email protected]>
Cc: [email protected]
Date: Mon, 21 Jul 2008 11:30:07 +0200
Rowland, J (James) wrote:
[...] Iâd like to do some array calculations (FFT, rectangular to polar, filtering etc). Iâd like the option to run at high rates (KHz) which would suggest using asyn. Is there any standard for this? I could easily put the calculations in the asyn layer but I canât see an obvious way to build a processing chain with only one link. Any suggestions? [...]
My 2 cent: my "standard approach" to implement complex algorithms on IOCs is, to use many records connecting to the same device support.
You can use one waveform record to feed the raw data to the device support and another to contain the FFT results.
You may need to feed additional parameters of your FFT into the device support by output records or read out diagnostics into input records.
I personally use SNL only for state machines, for algorithms I prefer a simple device support.
This approach does not produce any overhead, since you are basically passing pointers.
I'm always reluctant to pass MB of data with kHz over channel access (but maybe I'm old fashioned here ;-)
Also is there a standard for inverse subarray? Iâd like to combine 100s of scalar PVs into one waveform. [...]
I agree that an "inverse subarray" and a "waveout" record would be nice in EPICS base.
Of course one can do both with a device support, but I would find a record implementation cool.
Has somebody developed any of both records? If yes: how about adding it to base?
Andreas
RE: array calc / inverse subarray survey? Rowland, J (James)
Prev: How to introduce usage of genSub ? haquin
Next: RE: array calc / inverse subarray survey? Rowland, J (James)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: array calc / inverse subarray survey? Mark Rivers
