Subject: Re: Building 32-bit EPICS binaries on 64-bit Linux systems
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 18 Jul 2008 09:14:27 -0500
Mark,
For R3.14.9 add the following 2 lines to  CONFIG.Common.linux-x86
ARCH_DEP_CFLAGS += -m32
ARCH_DEP_LDFLAGS += -m32
Also you could add the following 2 lines to  CONFIG.Common.linux-x86_64
ARCH_DEP_CFLAGS += -m64
ARCH_DEP_LDFLAGS += -m64
Janet
Mark Rivers wrote:
Folks,
I want to build EPICS in 32-bit mode on a 64-bit Linux machine.  I had assumed that all I needed to do was to define EPICS_HOST_ARCH to be linux-x86, rather than linux-x86_64.  But when I do this it creates the expected directories and binaries, e.g. bin/linux-x86/caRepeater, etc. but the binaries appear to be 64-bit.  Running “file” on them reports them at ELF 64-bit files.  My IOC is crashing, and I suspect it is because it is built as a 64-bit application.   How do I force it to be built as a 32-bit application?  This is EPICS R3.14.9.
RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Prev: MAXv problem update EPICS record jerome HOSSELET
Next: RE: array calc / inverse subarray survey? Mark Rivers
Prev: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Next: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
