Subject: RE: Building 32-bit EPICS binaries on 64-bit Linux systems
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Cc: Dr Jon Kelly <[email protected]>
Date: Mon, 21 Jul 2008 14:57:52 -0500
Thanks Andrew.  What is the projected release date for R3.14.10?  I will
look to see if I can find problems with asyn and SNL, since I do seem to
have code that does not work.
-----Original Message-----
Sent: Monday, July 21, 2008 2:34 PM
To: [email protected]
Cc: Mark Rivers; Allison, Stephanie; [email protected]; Dr Jon Kelly
Subject: Re: Building 32-bit EPICS binaries on 64-bit Linux systems
On Friday 18 July 2008 13:15:03 Mark Rivers wrote:
> Where do things stand in EPICS in terms of running IOCs in 64-bit
mode?
Not recommended with R3.14.9 although many things do work; the problems
are in
the more obscure areas like numeric precision values when fetching
compound
DBF types.  I have put quite a lot of work recently into trying to round
up
64-bit issues in the IOC code, so I hope that R3.14.10 should be good
for
64-bit IOCs.
Note that you can't just go through and replace every 'long' with
an 'epicsInt32' in the source code because that would break source-code
compatibility with earlier versions.  I think what I have should be
source
compatible with most external device support and record types, although
some
changes might be necessary since DBF_LONG fields that used to be defined
as a
long are now an epicsInt32.
> However, a 64-bit IOC to control the Pilatus detector is failing.  It
> seems to be crashing in SNL code.  What parts of EPICS (base 4.14.9,
> asyn, SNL etc) are believed to be 64-bit safe and which are not?
I haven not looked at SNL or Asyn at all for 64-bit compatibility, nor
the
portable CAS in Base.  The Base libCom routines and the client side of
CA are
fine on 64-bit systems in R3.14.9.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: Building 32-bit EPICS binaries on 64-bit Linux systems Andrew Johnson
Prev: Re: Building 32-bit EPICS binaries on 64-bit Linux systems Andrew Johnson
Next: Amptek PX4 support? Rodney R. Porter
Next: Re: Building 32-bit EPICS binaries on 64-bit Linux systems Janet Anderson
