1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Revisiting a old problem - measuring the insertion device gap
To: [email protected]
Date: Tue, 22 Jul 2008 09:34:35 -0500
Community,
We have been tasked with designing an interlock system involving the measurement of our Insertion Devices here at the APS. Being a machine protection system, it would be preferable to use an independent source of measurement than is currently used by the control system. In the past it has been an awkward problem coming up with accurate absolute measurements of the gap due primarily to the fact that - by necessity - the area to be measured is typically under a high radiation environment.
I'm trying to approach this problem from a fresh start - without any of the existing baggage currently encumbering the control system.
So my question to everyone is simple to state, but I cannot come up with a reasonable solution:
1) For each Insertion Device (ID) the system will need accurate (within a few microns) and absolute measurement of the gap in two places (up and down-stream).
2) The transducers need to be radiation "proof" - things like plastics, teflon and electronics will not survive long enough (if at all) to be viable
In a nutshell, that's really it.
I've investigated a few leads which seem promising, but would like to hear fresh ideas from the experts (you guys).
Thanks in advance,
--Josh
RE: Revisiting a old problem - measuring the insertion device gap Deborah Quock
Re: Revisiting a old problem - measuring the insertion device gap David Morris
Re: Revisiting a old problem - measuring the insertion device gap Oleg Makarov
VXI resource manger converted to R3.14? Nicholas P. DiMonte
Re: VXI resource manger converted to R3.14? Andrew Johnson
Prev: procServ soft IOC server - V2.4.0 released Ralph Lange
Next: RE: Revisiting a old problem - measuring the insertion device gap Deborah Quock
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VXI resource manger converted to R3.14? Andrew Johnson
