1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Revisiting a old problem - measuring the insertion device gap
To: [email protected]
Date: Tue, 22 Jul 2008 08:32:07 -0700
Hi Josh,
We have used Absocoder multi turn absolute position encoders made by NSD in Japan in our cyclotron with good success. There are single and multi-turn rotary versions and linear types as well. They have a 16 bit parallel output word from the controller, and we have cable lengths to the encoder head of about 200 feet.
They are distributed in North America by www.enpromech.com
Cheers
David
Josh Stein wrote:
Community,
We have been tasked with designing an interlock system involving the measurement of our Insertion Devices here at the APS. Being a machine protection system, it would be preferable to use an independent source of measurement than is currently used by the control system. In the past it has been an awkward problem coming up with accurate absolute measurements of the gap due primarily to the fact that - by necessity - the area to be measured is typically under a high radiation environment.
I'm trying to approach this problem from a fresh start - without any of the existing baggage currently encumbering the control system.
So my question to everyone is simple to state, but I cannot come up with a reasonable solution:
1) For each Insertion Device (ID) the system will need accurate (within a few microns) and absolute measurement of the gap in two places (up and down-stream).
2) The transducers need to be radiation "proof" - things like plastics, teflon and electronics will not survive long enough (if at all) to be viable
In a nutshell, that's really it.
I've investigated a few leads which seem promising, but would like to hear fresh ideas from the experts (you guys).
Thanks in advance,
--Josh
--- avast! Antivirus: Inbound message clean. Virus Database (VPS): 080720-0, 07/20/2008 Tested on: 7/22/2008 8:00:36 AM avast! - copyright (c) 1988-2008 ALWIL Software. http://www.avast.com
David Morris TRIUMF
Systems Designer 4004 Wesbrook Mall
Ph 604-222-7450 Vancouver, B.C.
Fax 604-222-7307 V6T 2A3, Canada
avast! Antivirus: Outbound message clean.
Tested on: 7/22/2008 8:32:10 AM
VXI resource manger converted to R3.14? Nicholas P. DiMonte
Re: VXI resource manger converted to R3.14? Andrew Johnson
Revisiting a old problem - measuring the insertion device gap Josh Stein
Prev: RE: Revisiting a old problem - measuring the insertion device gap Deborah Quock
Next: Re: Revisiting a old problem - measuring the insertion device gap Oleg Makarov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
