Hi Isenegger,
There are example setup files in <top>/iocBoot/iocWithAsyn of
the motorRecord distribution. st.cmd.Vx has examples of the
configuration calls for the C-862
PIC862Setup() and PIC862Config()
That is where the connection to the asyn port is made.
I would recommend looking at the motor.substitutions file
(also in that directory) for a nice template for loading
motor records.
Your asyn port setup looks right to me.
Joe
Isenegger Andreas wrote:
Hello All,
According to the 'motor record' manual V6.1, the motor record has
support built in for the PI C-862 Mercury motor controller from Physik
Instrumente GmbH. It is connected via RS-232 to the IOC.
I am supposed to control this device via EPICS. It seems obvious to use
the motor record. However, I don't have the faintest clue what to put
into the 'OUT' field of the record to make it connect to the dedicated
serial channel. Can anybody help me here (example, documentation,
instructions, …)?
What I found out by doing a
#> grep device /work/iocBoot/R3.14.8/dbd/motor-test.dbd
is that I should write 'PIC862' into the DTYP field.
Furthermore, I think I know how to configure the asyn driver in the
startup script to open a serial port:
drvAsynSerialPortConfigure ("BusC863Ctrl", "/dev/ttyS0")
asynSetOption ("BusC863Ctrl", 0, "baud", "9600")
asynSetOption ("BusC863Ctrl", 0, "bits", "8")
asynSetOption ("BusC863Ctrl", 0, "parity", "none")
asynSetOption ("BusC863Ctrl", 0, "stop", "1")
asynSetOption ("BusC863Ctrl", 0, "clocal", "Y") # Y = ignore DTR/DSR
asynSetOption ("BusC863Ctrl", 0, "crtscts", "N") # N = ignore RTS/CTS
Any help appreciated.
Thanks and regards,
Andy
Andreas Isenegger
Section 'Control Systems'
Swiss Light Source
Paul Scherrer Institute, WBGB/003
CH-5232 Villigen PSI, Switzerland
Tel/Fax: ++41 (56) 310 5125/4413
Joseph Sullivan
[email protected] <> 630-252-8657
Advanced Photon Source
APS Engineering Services Division
Beamline Controls & Data Acquisition Group
- RE: EPICS support for PI C-862 Mercury motor controller Isenegger Andreas
- EPICS support for PI C-862 Mercury motor controller Isenegger Andreas
EPICS Meeting agenda Dalesio, Leo
Problems getting the Python module to work Adam Kadzban
<2008>
2025
<2008>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
