I’m working on deployment of an EPICS Gateway version
2.0.3.0 in our system here. I have the gateway running on a solaris-8
computer built against EPICS R3.14.9 with gcc 3.3.6. The gateway is
serving 2 VxWorks IOCs on a separate VLAN running EPICS R3.13.10 and VxWorkd
5.3.1.
According
to the following description for serverPostRate:
This is the rate in Hz at which events are posted to CAS. If the Gateway is
keeping up, this will be very close to the serverEventRate. If not, it will be
higher and all posted events will not have been processed.
It’s not good when the serverPostRate is higher than
the serverEventRate. When I look my gateway stats I see that my servoPostRate
is a lot higher than my serverEventRate, sometimes by as much as 2x, see
attached gateway_rates.pdf. The data was logged once every 10sec.
My load and cpu frac seems okay, see attached gateway_load.pdf.
Is there a way see what’s causing this and what can I
do about it?
Thank you in advance.
Kevin Tsubota
W.M. Keck Observatory
