1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS Gateway question
To: Kevin Tsubota <[email protected]>
Cc: [email protected]
Date: Wed, 13 Aug 2008 06:00:44 -0500
Hi Kevin,
I'm running about 40 PV gateways here at APS and I do see what you are
describing to some extent. There are times when there is a large
difference between the 2 rates but generally I see that they are usually
within 20 - 60 of each other. The bigger concern of mine is if the
exist test rates jump way up. This typically indicates that there are
clients asking for PVs that don't exist. I think that as long as the
server and client events track each other pretty well then there should
be no problem.
Hope this helps,
Marty
Kevin Tsubota wrote:
I’m working on deployment of an EPICS Gateway version 2.0.3.0 in our system here. I have the gateway running on a solaris-8 computer built against EPICS R3.14.9 with gcc 3.3.6. The gateway is serving 2 VxWorks IOCs on a separate VLAN running EPICS R3.13.10 and VxWorkd 5.3.1.
According to the following description for serverPostRate:
This is the rate in Hz at which events are posted to CAS. If the
Gateway is keeping up, this will be very close to the serverEventRate. If not, it will be higher and all posted events will not have been processed.
It’s not good when the serverPostRate is higher than the serverEventRate. When I look my gateway stats I see that my servoPostRate is a lot higher than my serverEventRate, sometimes by as much as 2x, see attached gateway_rates.pdf. The data was logged once every 10sec. My load and cpu frac seems okay, see attached gateway_load.pdf.
Is there a way see what’s causing this and what can I do about it?
Thank you in advance.
Kevin Tsubota
W.M. Keck Observatory
EPICS Gateway question Kevin Tsubota
Prev: Motor home status Pearson, MR (Matthew)
Next: Use of Easy CA ? Lecorche Eric
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: EPICS Gateway question Kevin Tsubota
Next: Re: EPICS Gateway question Dirk Zimoch
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
