Here is what I do: a Calcout record output its value into the VAL field of a Waveform record (using a Process Passive link triggering the processing of the Waveform). Then the Waveform record performs a Modbus/TCP write access with Asyn/Modbus device support. My problem is the following: Sometime though the last value is in the VAL field of the Waveform record it is not written via Modbus. I have already investigated on the Asyn/Modbus side, but it turns out that when the problem occurs Asyn/Modbus is not even called. It seems that the problem occurs when the Calcout record requests the Waveform record for a new Modbus write access but the Waveform record is still busy with the previous one... Can someone explain me how to be warned or informed when the processing request of a record is ignored because it is still busy (PACT=1). I tried setting field TPROC=1 to check if the Waveform trace is missing when the problem occur, but this is intrusive and the problem is then not reproducible... thanks. begin:vcard fn:Christophe Haquin n:Haquin;Christophe email;internet:[email protected] tel;work:02 31 45 46 61 x-mozilla-html:FALSE version:2.1 end:vcard
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
