Subject: Re: Question about a tutorial wiritten by Norum
To: [email protected]
Date: Tue, 30 Sep 2008 08:23:59 -0500
On Sep 30, 2008, at 7:58 AM, Silver wrote:
hi, all:
I want to write a driver for one of our serial devices, so I read "How to create EPICS device support for a simple serial or GPIB device". (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-9/HowToDoSerial/tutorial.html )
While I have several questions:
 1. in the tutorial, it said:
Command array index 0 – Device Reset
{&DSET_LO, GPIBWRITE, IB_Q_LOW, NULL, "\377\377\033", 10, 10,
NULL, 0, 0, NULL, NULL, "\033"},
I don't understand what's the meaning of "\377\377\033", does it mean "377" is oct number?
Yes. That's standard C syntax. If you prefer hexadecimal the equivalent would be "\xFF\xFF\x1B".
2. in function "convertPositionReply" and "convertStatusReply",
first time, pli->val = pdpvt->msg[0];
second time, pli->val = pdpvt->msg[1];
Does it mean the AB300's response data begin from different position? can anyone give me some explanation?
The AB300 response always contains both position information (in the first character) and status information (in the second character).
I have never used GPIB device before, so forgive my innocence. Thanks a lot in advance.
If your device is IEEE-488.2 compliant the makeSupport .pl command in the ASYN distribution will set up a number of command table entries that you could study. The command usage is:
<path to ASYN support module>/bin/<host archicture>/makeSupport.pl -t devGpib <yourDeviceName>
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Question about a tutorial wiritten by Norum Silver
Prev: Question about a tutorial wiritten by Norum Silver
Next: Re: How to be warned when a record processing is ignored because already busy (PACT=1) Tim Mooney
Next: Re:Re: Question about a tutorial wiritten by Norum marco_hair
