1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Inter-IOC link problems
To: "Shepherd, EL (Emma)" <[email protected]>
Cc: [email protected]
Date: Sat, 18 Oct 2008 12:15:01 +0200
Hello Emma,
in that setup your client IOC should see the beacons from the CA Gateway pointing its server side to the IOC - can you tell me the CA configurations of the two Gateway processes? (I.e. all their EPICS_* environment variables and/or command line options - I was not referring to the PV related configuration files in this case.)
Cheers,
Ralph
Shepherd, EL (Emma) wrote:
Hi there,
Thanks for the replies, it seems that the 'undefined' entry might have
been a red herring.
The IOC I am looking at is the client of the PV connection, and the IP
address listed is the server side of the CA gateway.  There are in fact
two gateways on this machine - one for each direction as you suggested.
The configuration is really very simple, it is setup to allow read
access for all PVs.  Do you need to know anything more specific?
Cheers,
Emma
RE: Inter-IOC link problems Shepherd, EL (Emma)
Prev: RE: Inter-IOC link problems Shepherd, EL (Emma)
Next: EPICS and CAN field bus Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Inter-IOC link problems Jeff Hill
Next: Desparately Looking for EDM 'Indicator' Widget Steve Lewis
