1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Inter-IOC link problems
To: <[email protected]>
Date: Fri, 17 Oct 2008 16:12:11 +0100
I've done a little more investigation and I think that in this case the
gateway is not to blame.  It seems that other CA links on this IOC are
also not working, and they are not all going through the gateway (some
are on other IOCs on the same network).
I setup caSnooper to monitor connection requests on one of the PVs my
IOC is failing to link to.  When I change the link to a constant and
change it back again, caSnooper does not report any new requests for the
PV.  However when I do the same on a 'healthy' IOC which has working
links, I see the new request on caSnooper when I put the link back.
I'm not sure what that tells me except that it looks like the IOC has
somehow stopped broadcasting search requests..?
Emma
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Shepherd,
> EL (Emma)
> Sent: 17 October 2008 12:28
> To: Ralph Lange
> Cc: [email protected]
> Hi there,
> Thanks for the replies, it seems that the 'undefined' entry
> might have been a red herring.
> The IOC I am looking at is the client of the PV connection,
> and the IP address listed is the server side of the CA
> gateway.  There are in fact two gateways on this machine -
> one for each direction as you suggested. The configuration is
> really very simple, it is setup to allow read access for all
> PVs.  Do you need to know anything more specific?
> Cheers,
> Emma
> > From: Ralph Lange [mailto:[email protected]]
> > Sent: 17 October 2008 08:52
> > To: Shepherd, EL (Emma)
> > Subject: Re: Inter-IOC link problems
> > Hi Emma,
> > I would need a bit more information about your setup to be
> > able to fully
> > understand your report.
> > You are looking at the CA client side of an IOC. When you are losing
> > connections between IOCs, is the IOC you're looking at the
> > server or the
> > client of that PV connection?
> > It seems there are no beacons coming from the CA Gateway
> > (172.23.106.35). Is that the client side or the server side
> of the CA
> > Gateway? Are two (or more) Gateway processes running on
> that machine
> > (i.e. one for each direction)? What is the CA configuration for the
> > Gateway(s) on that machine?
> > CA configuration of a Gateway is difficult and subtle. There
> > are a lot
> > of environment variables for CA server and client (see the
> CA Manual)
> > which influence the behaviour of a CA application. Some
> variables are
> > using other variables' values as default, which simplifies
> > configuration
> > of pure CA client or server apps, but may lead to unwanted
> > behaviour for
> > a CA Gateway (whis is one of the few apps that is as well CA
> > server and
> > client). E.g, it is quite easy to create a setup where the
> Gateway is
> > sending out beacons on the wrong (i.e. client) side.
> > Cheers,
> > Ralph
> > Shepherd, EL (Emma) wrote:
> > > Hi all,
> > > We still seem to suffer quite a bit from problems with
> > database links
> > > between IOCs, particularly when a gateway is involved.  For some
> > > reason the links can become disconnected and a reboot is usually
> > > necessary to get them working again.  I have just had an
> > opportunity
> > > to do some diagnosis on one such problem and found a clue
> in the CA
> > > beacon hashtable part of the dbcar report.  The entry for
> > the gateway
> > > (172.23.106.35) is 'undefined', although the gateway itself
> > seems to
> > > be working just fine and I can use caget through the gateway as
> > > normal.
> > > Any ideas what could cause this to happen, or how to fix
> it when it
> > > does?  None of the tasks are suspended, CPU usage is low and
> > > everything else looks fine.
> > > CA beacon hash entry for 172.23.106.32:5064 with period estimate
> > > 15.000521
> > >         beacon number 168436, on THU OCT 16 2008 14:27:46
> > > CA beacon hash entry for 172.23.106.35:5064 <no period estimate>
> > >         beacon number 0, on <undefined>
> > > CA beacon hash entry for 172.23.106.97:5064 with period estimate
> > > 14.988265
> > >         beacon number 76356, on THU OCT 16 2008 14:27:52
> > > CA beacon hash entry for 172.23.106.96:5064 with period estimate
> > > 14.988637
> > >         beacon number 39491, on THU OCT 16 2008 14:27:53
> > > CA beacon hash entry for 172.23.106.98:5064 with period estimate
> > > 14.980477
> > >         beacon number 58989, on THU OCT 16 2008 14:27:47
> > > CA beacon hash entry for 172.23.106.102:5064 with period estimate
> > > 14.990867
> > >         beacon number 39993, on THU OCT 16 2008 14:27:53
> > > 15.000521
> > > 14.988265
> > > 14.988637
> > > 14.980477
> > > 14.990867
> > entries per
> > > bucket: mean = 0.011719 std dev = 0.107617 max = 1
> > > Thanks in advance....
> > > Emma
> <DIV><FONT size="1" color="gray">This e-mail and any
> attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended
> addressee only. If you are not the intended addressee or an
> authorised recipient of the addressee please notify us of
> receipt by returning the e-mail and do not use, copy, retain,
> distribute or disclose the information in or attached to the
> e-mail. Any opinions expressed within this e-mail are those
> of the individual and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail
> or any attachments are free from viruses and we cannot accept
> liability for any damage which you may sustain as a result of
> software viruses which may be transmitted in or with the
> message. Diamond Light Source Limited (company no. 4375679).
> Registered in England and Wales with its registered office at
> Diamond House, Harwell Science and Innovation Campus, Didcot,
> Oxfordshire, OX11 0DE, United Kingdom </FONT></DIV>
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
RE: Inter-IOC link problems Jeff Hill
RE: Inter-IOC link problems Shepherd, EL (Emma)
Prev: Re: Converting Archive info to SDDS David Dudley
Next: Re: Inter-IOC link problems Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Inter-IOC link problems Shepherd, EL (Emma)
Next: RE: Inter-IOC link problems Jeff Hill
