1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Converting Archive info to SDDS
To: "Albert Kagarmanov" <[email protected]>
Cc: [email protected]
Date: Fri, 17 Oct 2008 08:31:22 -0500
So, I hear you're the man....
What I need is something that can take an Archive dataset, a list of
channels, and a time frame, and output a SDDS dataset that contains that
limited information.
We're starting to use the channelArchiver to do historical data
storage, and I need to figure out how to generate our compliance
reports.  They are usually done on a monthly basis, and based on what
I've read, it looks like I want to generate a SDDS datafile with the
data that the report needs.
David
>>> Matthias Clausen <[email protected]> 10/16/2008 5:21 PM >>>
Please contact Albert.
He has written a converter from the archiver to SDDS
-Matthias
Bob Soliday wrote:
> David Dudley wrote:
>> Is there a utility that will take a given snapshot from an Archive,
and
>> create a SDDS dataset with it?
>> David Dudley
> I haven't used the Channel Archiver and my attempts to compile it
have
> run in problems but from what I have read there is an ArchiveExport
> command that can convert the Archive to a spreadsheet. It should be
> possible to take this spreadsheet and convert it into SDDS format
with
> the plaindata2sdds program.
> --Bob Soliday
Matthias Clausen                         Cryogenic Controls
Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen
Synchrotron
fax:    +49-40-8994-3256                                    Notkestr.
85
e-mail: [email protected]                           22607
Hamburg
WWW-MKS2.desy.de
Germany
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Converting Archive info to SDDS David Dudley
Re: Converting Archive info to SDDS Bob Soliday
Re: Converting Archive info to SDDS Matthias Clausen
Prev: RE: Inter-IOC link problems Shepherd, EL (Emma)
Next: RE: Inter-IOC link problems Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Converting Archive info to SDDS Matthias Clausen
Next: EPICS and CAN field bus Ralph Lange
