1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Difficulties with my Sequencer program
To: "Szalata, Zenon M." <[email protected]>, "EPICS Techtalk" <[email protected]>
Date: Mon, 20 Oct 2008 11:40:31 -1000
Hi Zen,
When using the +r option, all variables are part of a structure. Use the
pointer "pVar" to access them, for example:
pVar-> foo
This is described in the SNL manual in the section on syntax (Section 5,
pg 20 in rev 1.9).
Erik
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Monday, October 20, 2008 11:06 AM
> To: EPICS Techtalk
> Subject: Difficulties with my Sequencer program
> I am using seq-R2-0-11 and vxWorks 6.6.
> I have written a simple sequencer program, which monitors a
> PV and when the epics record processes, it saves the data
> from the PV to a disk file.  The data written to disk is an
> ascii coded string, which contains configuration data for a
> VME module.  All of this works flawlessly with one module.
> I have a few such modules and I want to keep the
> configuration data in separate files, so this is what I tried:
> 1. I have coded my sequencer program such that I pass to it
> information using a macro, which is used to select which PV
> to monitor and get data from and what file name to use.
> 2. I start a few instances of the same program, one for each module.
> I realized that this does not work.  Looking at the manual
> for clues I see that the program must be made reentrant.
> Hence, I added option +r; to my program, but now it does not
> compile.  Here are some details:
> In the program I have a few routines written in C coded as
> escaped to C.  In the declaration part of the program I
> define a few variables, e.g. int update;. With the option +r;
> statement added, the C escaped routines no longer have access
> to the variables declared in the declaration part.  I get a
> number of error messages like:
> "../sncFFF.st:120: error: 'update' undeclared (first use in
> this function)"
> When I examine the sncFFF.c code generated with the +r option
> and without, I do not see any significant difference.
> I am stuck now and any help or suggestions will be greatly
> appreciated.
> Zen
Difficulties with my Sequencer program Szalata, Zenon M.
Prev: RE: Difficulties with my Sequencer program Mark Rivers
Next: ioc reading data from files Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
