1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.14.10-RC2 Build Problem
To: [email protected]
Date: Mon, 27 Oct 2008 19:24:21 +0100
Hi all,
in Epics versions before R3.14.10-RC2, it was possible to build
for a specific target arch only.
e.g.
> make vxWorks-68040
would create dirs O.Common and O.vxWorks-68040 only in R3.14.9,
In R3.14.10-RC2 the host arch will be built too and you end up with
O.Common, O.vxWorks-68040 and O.linux-x86.
This is a problem, because not all apps are supposed to compile with
the host arch.
Jens
Re: R3.14.10-RC2 Build Problem Andrew Johnson
Prev: RE: EPICS and CAN field bus David Beauregard
Next: Re: R3.14.10-RC2 Build Problem Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CAJ 1.1.5 and JCA 2.3.2 released Matej Sekoranja
