1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with LabVIEW Shared Memory Interface to EPICS IOC
To: "EPICS tech-talk" <[email protected]>
Date: Tue, 28 Oct 2008 08:43:33 +0100
I encountered problems with the LabVIEW Shared Memory Interface to EPICS
IOC.
I downloaded and installed following packages:
- EPICS Shared Memory Ver 3.14.7
- Beta 2 Installer of SNS Template
I followed the instructions in "LabVIEW Shared Memory Interface.doc" Version
2.3 Beta June 2005.
I am using LabVIEW 8.5. I had to correct for some Path2String conversion and
then the Example VIs were executable. I also started the caRepeater.
Then I started the server VIs of the examples first. The EPICS IOC was
started successfully and "dbl" displayed the expected PVs. Next I started
the client Vis. I changed the "DAC" and "Coefficient" valued and could
observer that this vales were received and processed by the server VI. In
parallel I was monitoring the PVs using caMonitor.
The problem is that the value of the "ADC" PV is not updated, neither in the
LV client nor in the caMonitor process. The same is true for the "Readback"
values. Stopping the server VI and restarting (I killed the running IOC)
results in updating the "ADC" and "Readback" values once only.
I guess that there is a problem with triggering the record processing in the
IOC via SM.
Questions:
- Does anybody has an idea how to solve the problem?
- Is a released version (not beta status) of the software available? I did
not found any newer.
- Is a LabVIEW 8.x version for the LabVIEW libraries available?
Thanks Holger
____________________________
GSI - Abteilung EE/KS
Dr. rer. nat. Holger Brand
Tel: +49 6159 71 2123
Fax: +49 6159 71 2986
eMail: [email protected]
Web: www.gsi.de/controls
GnuPG: http://www.gnupg.de/
- Key-ID=D55871D3
- Fingerprint=9337 0701 0756 25C6 E920 1040 15FE 7936 D558 71D3
- PublicKey: http://wiki.gsi.de/cgi-bin/view/Personalpages/PublicKey
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1
D-64291 Darmstadt
www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Prev: R3.14.10 Andrew Johnson
Next: Re: R3.14.10-RC2 Build Problem Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
