1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.10-RC2 Build Problem
Cc: [email protected]
Date: Tue, 28 Oct 2008 11:35:02 -0500
How to specify Makefile definitions which restrict builds to specific target architectures is described in Chapter 2, Section 4.3.7 of the R3.14.9 Application Developers Guide.
Janet
Andrew Johnson wrote:
Hi Jens,
On Monday 27 October 2008 13:24:21 Jens Eden wrote:
in Epics versions before R3.14.10-RC2, it was possible to build
for a specific target arch only.
e.g.
make vxWorks-68040
would create dirs O.Common and O.vxWorks-68040 only in R3.14.9,
In R3.14.10-RC2 the host arch will be built too and you end up with
O.Common, O.vxWorks-68040 and O.linux-x86.
This is a problem, because not all apps are supposed to compile with
the host arch.
Janet has managed to fix this for the final release, but I would actually
recommend that you fix the Makefile in those apps and not have to use that
technique at all.
There are a number of variables that allow you to restrict the architectures
that your code is compiled for, and if you get these right the problem
vanishes.  For example, instead of
    LIBRARY = app
if you say
    LIBRARY_vxWorks = app
then that library will only be compiled for vxWorks targets.  You'll still get
an O.linux-x86 directory, but it will be empty.
Here's an example Makefile from drvIpac/tyGSOctal, which creates a library
libTyGSOctal.a on vxWorks and RTEMS, and uses a different C source file for
each OS.  On other OSs it does nothing:
# Makefile
TOP = ..
include $(TOP)/configure/CONFIG
DBD += tyGSOctal.dbd
LIBSRCS_vxWorks += tyGSOctal.c
LIBSRCS_RTEMS += tyGSOctal_RTEMS.c
LIBRARY_IOC_vxWorks = TyGSOctal
LIBRARY_IOC_RTEMS = TyGSOctal
TyGSOctal_LIBS += Ipac
include $(TOP)/configure/RULES
The only thing the build system doesn't provide is the ability to restrict
builds to a specific target architecture rather than an OS class.  It's not
hard to do that yourself in the Makefile if you really need it though; I can
explain how on request.
- Andrew
R3.14.10-RC2 Build Problem Jens Eden
Re: R3.14.10-RC2 Build Problem Andrew Johnson
Prev: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
Next: function-name collision in edm/calcPv and epics/libCom/calc Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.10-RC2 Build Problem Andrew Johnson
Next: R3.14.10 Andrew Johnson
