1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: function-name collision in edm/calcPv and epics/libCom/calc
To: John Sinclair <[email protected]>, [email protected]
Date: Wed, 29 Oct 2008 13:59:03 +0100
while playing with the most recent edm (edm-1-11-1r) on my Linux-box, I discovered a naming-collision that may concern more than just me...
I was wondering, why edm suddenly complained about one of the expressions in our $EDMFILES/calc.list and quickly tracked it down to the expression-length - once it reached 100 chars, edm complained about
CALC:'escale': error in expression '...<our long expression>...'
I couldn't find any 100-chars limit in edm (especially calcPv/*), so I put some printf-statements into postfix.c:postfix() - and never saw any of them!
To make it short: in base/src/libCom/calc/postfix.c there is a function postfix() with the very same signature (but maybe a slightly different implementation).
And this one seems to hide the function defined in edm/calcPv.
We're using 3.14.8, where libCom/calc/postfix.c contains a '#define MAX_POSTFIX_SIZE 100' - this is why I stumbled upon this.
3.14.9 does not have this MAX_POSTFIX_SIZE anymore, so I wouldn't even have recognized the collision with 3.14.9.
If edm is to definitely use its own implementation of postfix(), we should remove this naming-collision and make sure, there are no others...
I just renamed it to edm_postfix() in my build-tree and everything works fine now.
The patch is trivial, but I attached it anyway...
Thomas
diff -ur edm-1-11-1r-ORIG/calcPv/calc_pv_factory.cc edm-1-11-1r/calcPv/calc_pv_factory.cc
--- edm-1-11-1r-ORIG/calcPv/calc_pv_factory.cc	2008-02-27 21:52:27.000000000 +0100
+++ edm-1-11-1r/calcPv/calc_pv_factory.cc	2008-10-29 13:50:06.000000000 +0100
@@ -56,7 +56,7 @@
     if ( rewriteString ) {
       expStr.setRaw( rewriteString );
-    if (postfix(formula, this->compiled, &error) != 0)
+    if (edm_postfix(formula, this->compiled, &error) != 0)
         fprintf(stderr, "CALC '%s': error in expression '%s'\n",
                 name, formula);
diff -ur edm-1-11-1r-ORIG/calcPv/postfix.c edm-1-11-1r/calcPv/postfix.c
--- edm-1-11-1r-ORIG/calcPv/postfix.c	2008-02-27 21:52:32.000000000 +0100
+++ edm-1-11-1r/calcPv/postfix.c	2008-10-29 13:46:51.000000000 +0100
@@ -307,7 +307,7 @@
  * convert an infix expression to a postfix expression
-long postfix(char *pinfix,char *ppostfix, short *perror)
+long edm_postfix(char *pinfix,char *ppostfix, short *perror)
 	short		no_bytes;
 	register short	operand_needed;
diff -ur edm-1-11-1r-ORIG/calcPv/postfix.h edm-1-11-1r/calcPv/postfix.h
--- edm-1-11-1r-ORIG/calcPv/postfix.h	2008-02-27 21:52:32.000000000 +0100
+++ edm-1-11-1r/calcPv/postfix.h	2008-10-29 13:46:51.000000000 +0100
@@ -42,7 +42,7 @@
 #endif
-long postfix (char *pinfix, char *ppostfix, short *perror);
+long edm_postfix (char *pinfix, char *ppostfix, short *perror);
 long calcPerform(const double *parg, double *presult, const char *post);
Prev: Re: R3.14.10-RC2 Build Problem Janet Anderson
Next: Tornado-2.0.x cross compiler Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
