On 11/10/08 12:49 PM, Peter Zumbruch wrote:
> Hi,
> I am facing the following problem.
> I try to compile msi 1.4 using base 3.14.10.
> I get the following crash.
> make -C ./msi1_4 install
> make[1]: Entering directory `<EPICS Extension Dir>/src/msi1_4'
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[2]: Entering directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86'
> /usr/bin/gcc-3.4 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
> -ansi -O3 -Wall -m32 -g -I. -I../O.Common -I. -I..
> -I../../../include/os/Linux -I../../../include
> -I../../../../base-3.14.10/include/os/Linux
> -I../../../../base-3.14.10/include -I../../../include ../msi.c
> ../msi.c: In function `main':
> ../msi.c:69: error: `TRUE' undeclared (first use in this function)
> ../msi.c:69: error: (Each undeclared identifier is reported only once
> ../msi.c:69: error: for each function it appears in.)
> ../msi.c:86: error: `FALSE' undeclared (first use in this function)
> ../msi.c: In function `makeSubstitutions':
> ../msi.c:167: error: `TRUE' undeclared (first use in this function)
> ../msi.c:225: error: `FALSE' undeclared (first use in this function)
> ../msi.c: In function `inputAddPath':
> ../msi.c:298: error: `TRUE' undeclared (first use in this function)
> ../msi.c:298: error: `FALSE' undeclared (first use in this function)
> ../msi.c: In function `freePattern':
> ../msi.c:506: error: `FALSE' undeclared (first use in this function)
> ../msi.c: In function `substituteGetNextSet':
> ../msi.c:551: error: `FALSE' undeclared (first use in this function)
> ../msi.c:553: error: `TRUE' undeclared (first use in this function)
> ../msi.c: In function `substituteGetReplacements':
> ../msi.c:616: error: `FALSE' undeclared (first use in this function)
> ../msi.c:630: error: `TRUE' undeclared (first use in this function)
> ../msi.c: At top level:
> ../msi.c:487: warning: 'freeSubFile' defined but not used
> make[2]: *** [msi.o] Error 1
> make[2]: Leaving directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86'
> make[1]: *** [install.linux-x86] Error 2
> make[1]: Leaving directory `<EPICS Extension Dir>/src/msi1_4'
> make: *** [msi1_4.install] Error 2
> My system is a debian sarge (3.1) clone using gcc3.4 and gmake 3.81.
> Any idea?
> Hints would be appreciated.
> Compiling the same code against 3.14.9 succeeds.
> Best regards,
> Peter
Hi, Peter.
I have the same problem on Mac OS X 10.5.5. It seems that msi.c expects
TRUE and FALSE to be defined. If I include dbDefs.h, which includes
defines for these, it will successfully compile. Attached is a patch.
However, I don't know what the intended use of dbDefs.h is. It could be
that this should not be used by msi. If this is the case, then one
could just define TRUE and FALSE in msi.c like this:
#define TRUE 1
#define FALSE 0
Or, one could replace all the TRUE and FALSE references in the file to 1
and 0 respectively.
Lewis
--- msi.c.orig 2004-06-14 14:02:00.000000000 -0400
+++ msi.c 2008-11-10 14:07:57.000000000 -0500
@@ -21,6 +21,7 @@
#include <ctype.h>
#include <errno.h>
+#include <dbDefs.h>
#include <macLib.h>
#include <ellLib.h>
- msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Andrew Johnson
C++ and genSubRecord.h Pierrick Hanlet
<2008>
<2008>
