1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fast Cross-IOC Loops?
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 12 Nov 2008 09:51:03 -0500
If you are talking about doing it over the network connection I have
used used UDP packets before in some robotics applications. I built the
app using sun RPC which is UDP based.  You do have a packet size limit,
you have to be able to tolerate dropped packets, and if vxWorks it still
has to go through tNetTask in-bound.  With TCP it becomes a byte stream
and the OS is free to pack things any way it wants so you have no
control over timing, as compared with little control with UDP.  Getting
200 Hz depends on how much network you have to go through.  We once
teleoperated a robot over a link from Sandia Labs NM to Oak Ridge, not
at 200 Hz obviously.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Wednesday, November 12, 2008 9:20 AM
To: EPICS Tech Talk
Subject: Fast Cross-IOC Loops?
Hello!
What would be the smartest way to implement fast cross-IOC loops that
are high-priority?
Problem: The CA server tasks on the target IOC are low priority (for
good reasons, I know!), so that - even with a fast synchronous device
support - any stupid slow-and-low record processing on that IOC will
introduce delays, which leads to jitter or multiple CA updates before
the target record gets processed.
Oh, yes: "fast" would be something below 200Hz.
Any hints welcome...
Ralph
Fast Cross-IOC Loops? Ralph Lange
Prev: Re: question about s7-plc driver by Dirk Dirk Zimoch
Next: Re: question about ca gateway Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fast Cross-IOC Loops? Ralph Lange
Next: Re: Fast Cross-IOC Loops? Dirk Zimoch
