Subject: Re: Fast Cross-IOC Loops?
To: Ralph Lange <[email protected]>
Date: Wed, 12 Nov 2008 14:33:00 -0300
We use reflective memory (GeFanuc) to convey fast information between remotely separate systems. The nodes come in different h/w flavor (PCI, VME,...) linked by fiber. Our nominal rate is 200Hz.
I don't know if thats the cross-IOC solution you are looking - if you think a big pool of memory that can shared between remote processes, that as wake-up/broadcast capabilities, that might be an option. It's been good for us!
Matthieu
Ralph Lange wrote:
Hello!
What would be the smartest way to implement fast cross-IOC loops that are high-priority?
Problem: The CA server tasks on the target IOC are low priority (for good reasons, I know!), so that - even with a fast synchronous device support -
any stupid slow-and-low record processing on that IOC will introduce delays, which leads to jitter or multiple CA updates before the target record gets processed.
Oh, yes: "fast" would be something below 200Hz.
Any hints welcome...
Ralph
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
Fast Cross-IOC Loops? Ralph Lange
Prev: Re: Fast Cross-IOC Loops? Dirk Zimoch
Next: WireSet missing with 3.14.10 Dehong Zhang
Prev: Re: Fast Cross-IOC Loops? Jukka Pietarinen
Next: RE: Fast Cross-IOC Loops? Thompson, David H.
