1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fast Cross-IOC Loops?
To: Dirk Zimoch <[email protected]>
Cc: EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Wed, 12 Nov 2008 21:26:19 +0200
Hi Dirk,
Dirk Zimoch wrote:
Answer two: We are working on a solution to use the data buffer of the timing system for real-time communication. We will need such a fast channel for our FEL. At the moment, the data flow is only one way. We hope that "upstream" communication will be possible soon (depending how busy Jukka is).
The upstream communication is already available for CompactPCI/PXI modules and PMC, but I guess you want it for VME. Actually I have the firmware built for VME, too, but I have not yet found time to test it.
Another bigger issue is that there have been a major changes in the register map and the the EPICS drivers need to be rewritten to support the new 'modular register mapping'. There have also been discussions of getting rid of the eg and er records and implement the new drivers using asyn.
Jukka
Fast Cross-IOC Loops? Ralph Lange
Re: Fast Cross-IOC Loops? Dirk Zimoch
Prev: WireSet missing with 3.14.10 Dehong Zhang
Next: Re: WireSet missing with 3.14.10 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fast Cross-IOC Loops? Dirk Zimoch
Next: Re: Fast Cross-IOC Loops? Matthieu Bec
