1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: WireSet missing with 3.14.10
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Thu, 13 Nov 2008 16:21:57 -0600
Hi Dehong,
On Thursday 13 November 2008 15:11:02 Dehong Zhang wrote:
> We need the "vxWorks6-mv5100" architecture, but the base package does not
> have it.
Ah, that's the problem, no you don't; the vxWorks6 targets have been merged
back into the regular vxWorks ones (they should never have been added to
3.14.8 in the first place).  Use the supplied vxWorks-ppc604_long or
vxWorks-ppc604_altivec targets instead; if your MVME5100 board has an MPC750
CPU use vxWorks-ppc604_long, but if your board is really an MVME5110 and has
a MPC7410 CPU with altivec enabled then use vxWorks-ppc604_altivec instead.
I suggest you:
1. Delete all the vxWorks6 files you created under base/configure/os
2. Edit base/configure/os/CONFIG_SITE.Common.vxWorksCommon and define the
WIND_BASE setting in there to point to your vxWorks 6 installation
3. Edit base/configure/CONFIG_SITE and change CROSS_COMPILER_TARGET_ARCHS to
use the appropriate target(s) as described above
4. In the base top level directory, run 'make distclean; make'
5. Repeat step 4 for all your support modules
6. In your IOC area, edit the iocBoot/ioc*/Makefile and change the setting for
ARCH to the correct architecture as discussed above, then 'make distclean;
make' in the application top level directory and try booting the IOC.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: WireSet missing with 3.14.10 Dehong Zhang
Re: WireSet missing with 3.14.10 Andrew Johnson
Prev: Re: WireSet missing with 3.14.10 Dehong Zhang
Next: Re: Re: question about ca gateway, 万天敏
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: WireSet missing with 3.14.10 Dehong Zhang
