1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: question about ca gateway,
To: "Dirk Zimoch" <[email protected]>
Date: Fri, 14 Nov 2008 09:32:35 +0800
Hello,Dirk Zimoch
    Do as you said, I set the EPICS_CA_ADDR_LIST and EPICS_CA_SERVER_PORT to the gateway's sip and sport on client ,the client can get the pv even in situation of gateway display  error messages. Thanks for your help, by means of this; the user can get the pv when some ioc is configured incorrectly.
 Best Regards
 wantianmin
Re: Re: question about ca gateway 万天敏
Re: question about ca gateway Dirk Zimoch
Prev: Re: WireSet missing with 3.14.10 Andrew Johnson
Next: USE of CA lib: problem using ca_array_put_callback with strings haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about ca gateway Dirk Zimoch
Next: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
