Steve Lewis wrote:
Just to clarify:
There are two instances of iocLogServer running.
The first is doing conventional IOC logging. So your st.cmd would
have set the environment variables EPICS_IOC_LOG_INET and
EPICS_IOC_LOG_PORT and have the line:
iocLogInit()
The second is doing caput logging, using port 7010. So your st.cmd
would have:
caPutLogInit("${EPICS_IOC_LOG_INET}:7010")
So this ignores EPICS_IOC_LOG_INET and EPICS_IOC_LOG_PORT?
Hi Steve,
I actually have the caput logging going to the same place as the IOC
conventional logging.
That is my recommendation so that I can easily correlate operator
changes with possible errors/messages from the IOC. :)
So, I am using:
# Turn on caPutLogging:
# Log values only on change to the iocLogServer:
caPutLogInit("172.27.8.31:7004")
caPutLogShow(2)
The above will send messages to my already running iocLogServer.
By the way, the CSS collaboration is working on a messaging system
for EPICS. I am not sure of the current status.
Ernest
Steve
[I added techtalk to the CC list. This might be of interest to others.]
On Tuesday 18 November 2008 14:45, Steve Lewis wrote:
This sounds great, Ernest. Can you tell me exactly how this fills
the need? (I see in subsequent e-mails how you got it to come up.)
In fact, I have not brought up iocLogServer yet, either. Can you
give me a brief sketch of how that is configured?
At 9:28 PM -0800 2008/11/17, Ernest L. Williams Jr. wrote:
>I have found that a combination of autosave/restore and caPutLogging
>will give me the same functionality as the ChannelWatcher:
It is very simple. Set two environment variables
EPICS_IOC_LOG_FILE_NAME=/path/to/logfilename and
EPICS_IOC_LOG_PORT=portnumber and then start iocLogServer (from epics
base). I have attached a small shell script I use to start the log
servers
on my local machine.
Cheers
Ben
- Re: caPutLogging Documentation Benjamin Franksen
- Re: caPutLogging Documentation Matthias Clausen
CAEN V965 driver Szalata, Zenon M.
<2008>
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
