On Tuesday 18 November 2008 11:34:10 David Dudley wrote:
> Is there a predefined method of generating a system that contains 'debug'
> labels and source line references?
For R3.14.10 Janet added -debug versions of many of the target architectures,
so for example you can cross-build the linux-x86-debug target on a linux-x86
host and you'll be able to run either the regular or the debug version of
your code. Alternatively set your EPICS_HOST_ARCH to linux-x86-debug and
just build and use that normally.
> I see in the configure files that there is a variable called
> 'OPT_CFLAGS_YES' and 'OPT_CFLAGS_NO", but don't see any way to use them.
The variables HOST_OPT and CROSS_OPT control which one gets used; set them to
YES or NO in your configure/CONFIG_SITE or configure/os/CONFIG_SITE.*.* files
as appropriate.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Building system with Debug David Dudley
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Re: caPutLogging Documentation Benjamin Franksen
<2008>
priority callback tasks Kevin Tsubota
<2008>
