1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: NTP-Time on RTEMS(vxWorks) Problem
To: [email protected]
Date: Fri, 28 Nov 2008 13:45:50 +0100
Hi all,
we found a problem when synchronizing Time on RTEMS targets
with the new NTP-TimeProvider in Release 3.14.10.
NTPTimeSync() writes the NTP-time to the internal buffer only,
if IOC-time is behind NTP-time. Since steps backwards in time
should be avoided, the ticksToSkip-counter is incremented in the
other case and the new NTP-time is disregarded.
If IOC-Time is constantly faster then NTP-Time, the ticksToSkip-
counter increases over the time and IOC-time is never adjusted.
This has the effect, that every minute IOC-Time stops for an
increasing period of time, before jumping back to its original time.
Since VxWorks targets use the same code, I presume they are affected too.
Attached is a patch to set the IOC-time in all cases.
Jens
--- base-3.14.10/src/libCom/osi/osiNTPTime.c    2008-09-15 23:26:33.000000000 +0200
+++ base-3.14.10-1/src/libCom/osi/osiNTPTime.c  2008-11-28 12:57:46.000000000 +0100
@@ -181,11 +181,11 @@
         epicsMutexMustLock(NTPTimePvt.lock);
         diff = epicsTimeDiffInSeconds(&timeNow, &NTPTimePvt.clockTime);
         if (diff >= 0.0) {
-            NTPTimePvt.clockTime = timeNow;
             NTPTimePvt.ticksToSkip = 0;
         } else { /* dont go back in time */
             NTPTimePvt.ticksToSkip = -diff * NTPTimePvt.ticksPerSecond;
+        NTPTimePvt.clockTime = timeNow;
         NTPTimePvt.clockTick = tickNow;
         NTPTimePvt.synchronized = 1;
         epicsMutexUnlock(NTPTimePvt.lock);
Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
Prev: RE: nidaqmxbase synapps module Pedersen, UK (Ulrik)
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
