1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sscan compile error on base 3.14.10 on linux
To: Tim Mooney <[email protected]>
Cc: "John M. Skinner" <[email protected]>, [email protected]
Date: Tue, 02 Dec 2008 09:50:30 +0100
Hi Tim,
Arithmetic with macros like EPICS_MODIFICATION<(l) only works if EPICS_MODIFICATION is numeric. This is not guaranteed. In pre-releases like 3.14.10-pre1 we have:
# This part may contain letters, eg 0beta1
EPICS_MODIFICATION = 10pre1
Of course it would be nice to have a mechanism to find out the current EPICS release, but EPICS does not provide this feature.
Dirk
Tim Mooney wrote:
John,
You can fix the scanOnce errors like this:
   scanOnce((struct dbCommon *)psscan);
and the precision problem like this:
   pPos->p_pr = precPvt->pDynLinkInfo->precision.dp;
But note that the precision fix is base-version dependent.  The current
sscanRecord code actually looks like this:
#include <epicsVersion.h> /* for LT_EPICSBASE macro */
/* Less than EPICS base version test.*/
#define LT_EPICSBASE(v,r,l) ((EPICS_VERSION<=(v)) && (EPICS_REVISION<=(r)) && (EPICS_MODIFICATION<(l)))
#if LT_EPICSBASE(3,14,10)
pPos->p_pr = precPvt->pDynLinkInfo->precision;
#else
#endif
Tim
John M. Skinner wrote:
I'm trying to build sscan 2.6.2 on EPICS base 3.14.10 but get these compile warnings and errors:
../sscanRecord.c: In function `special':
../sscanRecord.c:1451: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c:1585: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `notifyCallback':
../sscanRecord.c:2457: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `userGetCallback':
../sscanRecord.c:2523: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `pvSearchCallback':
../sscanRecord.c:2613: error: incompatible types in assignment
../sscanRecord.c:2643: error: incompatible types in assignment
../sscanRecord.c:2743: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `posMonCallback':
../sscanRecord.c:2818: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `doPuts':
../sscanRecord.c:4013: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c:4190: warning: passing arg 1 of `scanOnce' from incompatible pointer type
I get the same results on both Fedora Core 3 and Fedora Core 8. I have no problem building the scan record on EPICS base 3.14.9.
thanks,
John Skinner (BNL/NSLS)
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: sscan compile error on base 3.14.10 on linux Tim Mooney
Re: sscan compile error on base 3.14.10 on linux Andrew Johnson
sscan compile error on base 3.14.10 on linux John M. Skinner
Prev: Re: solaris-x86 build error on 3.14.10 Andrew Johnson
Next: Re: sscan compile error on base 3.14.10 on linux Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sscan compile error on base 3.14.10 on linux Tim Mooney
