1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compile error about gateway
To: [email protected]
Date: Wed, 03 Dec 2008 16:20:38 +0100
Hi Geyang,
You are probably compiling with base  3.14.10? There are some (secret) changes
between 3.14.8.2 and 3.14.9 which require some modifications in the source code.
Have a look in gateVc.cc lines 1012-1014. Comment line 1013 and uncomment line
1014.
Maybe I should add some macro tests for EPICS_MODIFICATION, but there are other
problems, eg. when using pre-releases (See my reply on the "sscan compile error
on base 3.14.10 in linux" thread).
Dirk
Silver wrote:
> hi, all:
> I think I would disturb Dirk to see thsi again. :)
> when I tried to compile gateway2_0_2_1 on centOS 5.2, there is an error like following:
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[1]: Entering directory `/usr/local/epics/extensions/src/gateway2_0_2_0/O.linux-x86'
> /usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM      -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../base/include/os/Linux -I../../../../base/include -I../../../include/os/Linux -I../../../include     -I../../../../base/src/cas/generic    ../gateVc.cc
> ../../../../base/include/gddUtils.h:85: warning: 'class gddDestructor' has virtual functions but non-virtual destructor
> ../../../../base/include/gddUtils.h: In member function 'char* gddDestructor::newdel_next()':
> ../../../../base/include/gddUtils.h:96: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddUtils.h: In member function 'void gddDestructor::newdel_setNext(char*)':
> ../../../../base/include/gddUtils.h: In member function 'char* gddBounds1D::newdel_next()':
> ../../../../base/include/gddUtils.h:117: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddUtils.h: In member function 'void gddBounds1D::newdel_setNext(char*)':
> ../../../../base/include/gddUtils.h: In member function 'char* gddBounds2D::newdel_next()':
> ../../../../base/include/gddUtils.h:129: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddUtils.h: In member function 'void gddBounds2D::newdel_setNext(char*)':
> ../../../../base/include/gddUtils.h: In member function 'char* gddBounds3D::newdel_next()':
> ../../../../base/include/gddUtils.h:141: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddUtils.h: In member function 'void gddBounds3D::newdel_setNext(char*)':
> ../../../../base/include/gdd.h: In member function 'char* gdd::newdel_next()':
> ../../../../base/include/gdd.h:468: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gdd.h: In member function 'void gdd::newdel_setNext(char*)':
> ../../../../base/include/gddI.h: In member function 'void gdd::setStat(aitUint16)':
> ../../../../base/include/gddI.h:106: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddI.h: In member function 'void gdd::setSevr(aitUint16)':
> ../../../../base/include/gddI.h:108: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddI.h: In member function 'aitUint16 gdd::getStat() const':
> ../../../../base/include/gddI.h:110: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/gddI.h: In member function 'aitUint16 gdd::getSevr() const':
> ../../../../base/include/gddI.h:112: warning: dereferencing type-punned pointer will break strict-aliasing rules
> ../../../../base/include/fdManager.h: At global scope:
> ../../../../base/include/fdManager.h:39: warning: 'class fdRegId' has virtual functions but non-virtual destructor
> ../../../../base/include/gddAppTable.h:65: warning: 'class gddApplicationTypeDestructor' has virtual functions but non-virtual destructor
> ../gateVc.cc: In member function 'virtual caStatus gateVcData::read(const casCtx&, gdd&)':
> ../gateVc.cc:1013: error: 'AlignedWireRef' was not declared in this scope
> ../gateVc.cc:1013: error: expected primary-expression before '>' token
> make[1]: *** [gateVc.o] Error 1
> make[1]: Leaving directory `/usr/local/epics/extensions/src/gateway2_0_2_0/O.linux-x86'
> make: *** [install.linux-x86] Error 2
> If I comment out that line "ca_uint16_t caProtoMask = AlignedWireRef < epicsUInt16 >(pMonInfo->m_mask);" , it can pass, why?
> On fedora core, gateway could be compiled. Can anyone give me some help? thanks a lot in advance
> Best regards
> Geyang  2008-12-03
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: Re: compile error about gateway Silver
Prev: Alarms vs. Interlocks Re: How to implement simple control algorithm Kasemir, Kay
Next: Re: A bug of calc record? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: compile error about gateway Silver
Next: Re: Re: compile error about gateway Silver
