1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM screen go white
To: tech-talk <[email protected]>
Date: Mon, 8 Dec 2008 19:34:01 +0800 (CST)
Dear all,
    I have one OPI with base3.14.9-prel on Red Hat 9, and one IOC with base3.14.9-prel on Red Hat
 Enterprise Linux WS 4. The IP of the IOC I set is 192.168.1.1, and the OPI is 192.168.1.2.
 after "ping" and "ifconfig", on IOC it gets:
[root@localhost ~]# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0B:DB:C2:96:D8
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::20b:dbff:fec2:96d8/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:740 (740.0 b)  TX bytes:1330 (1.2 KiB)
          Interrupt:201
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:1706 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1706 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1978328 (1.8 MiB)  TX bytes:1978328 (1.8 MiB)
on OPI it gets:
[root@localhost root]# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:11:09:08:A1:1E
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:272 errors:0 dropped:0 overruns:0 frame:0
          TX packets:149 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:27964 (27.3 Kb)  TX bytes:30118 (29.4 Kb)
          Interrupt:21 Base address:0xb000
          RX packets:11864 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11864 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:757526 (739.7 Kb)  TX bytes:757526 (739.7 Kb)
   I set the Environment Variables EPICS_CA_ADDR_LIST=192.168.1.2 and EPICS_CA_AUTO_ADDR_LIST=NO
on the IOC. when running the IOC , the IOC can't work correctly ,it gets:
epics>../online_notify.c:CA beacon (send to "192.168.1.255:5065")error was "Connection refused"
  Then I set EPICS_CA_ADDR_LIST=192.168.1.1 and EPICS_CA_AUTO_ADDR_LIST=NO
on the OPI. After rebooting the IOC, there is no error message, but the MEDM screen go white. running
casr 10 on IOC, it gets:
epics> casr 10
Channel Access Server V4.11
No clients connected.
UDP Server:
UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
        Task Id=0x92d4e70, Socket FD=7
        Secs since last send  16.46, Secs since last receive  16.46
        Unprocessed request bytes=16, Undelivered response bytes=0
        State=up
        180 bytes allocated
        Send Lock
epicsMutexId 0x92dad20 source ../caservertask.c line 699
        Put Notify Lock
epicsMutexId 0x9341e78 source ../caservertask.c line 700
        Address Queue Lock
epicsMutexId 0x9341eb0 source ../caservertask.c line 701
        Event Queue Lock
epicsMutexId 0x9341ee8 source ../caservertask.c line 702
        Block Semaphore
There are currently 1260 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (16408 bytes ea)
The server's array size limit is 16408 bytes max
Channel Access Address List
192.168.1.255:5065
192.168.1.2:5065
epics>
appreciation for any suggestion
Best Wishes
                                                Demin Zhang
[广告] 2008年最受关注楼盘
RE: MEDM screen go white Mark Rivers
Prev: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Steve Banks
Next: RE: MEDM screen go white Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
