1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DeltaTau UMAC ethernet access?
To: "Dirk Zimoch" <[email protected]>, "tech-talk" <[email protected]>
Date: Tue, 9 Dec 2008 14:14:25 -0000
Dirk,
Which Delta Tau UMAC drivers are you using? The driver on the GSECARS
site http://www.gmca.aps.anl.gov/TPMAC2/ was initially developed for a
UMAC ethernet interface. It is an interpose interface for AsynIPPort.
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Dirk Zimoch
> Sent: 09 December 2008 14:05
> To: tech-talk
> Subject: DeltaTau UMAC ethernet access?
> Hi all,
> Is there a driver for the DeltaTau UMAC ethernet interface?
> I could only find drivers for VME based or PCI based PMAC
> controllers but not
> for controllers (Turbo PMAC 2 CPU) connected via ethernet or
> USB. The protocol
> seems to be the same as for other DeltaTau controller types,
> only the data
> transfer layer is different (uses UDP). A typical case for
> asynOctet, I think.
> Dirk
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Scanned by iCritical.
RE: DeltaTau UMAC ethernet access? Pearson, MR (Matthew)
RE: DeltaTau UMAC ethernet access? Mark Rivers
Re: DeltaTau UMAC ethernet access? Dirk Zimoch
Prev: DeltaTau UMAC ethernet access? Dirk Zimoch
Next: RE: DeltaTau UMAC ethernet access? Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
