1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DeltaTau UMAC ethernet access?
To: "Rees, NP (Nick)" <[email protected]>
Date: Tue, 09 Dec 2008 15:56:19 +0100
Hi Nick, Matthew, Mark,
Thanks for the quick reply. I think the TPMAC2 driver will do. I will try it. It it my first PMAC device (or UMAC? What is the difference?)
At the moment, the system is controlled by 3rd party software running on a Windows PC. Apparently it uses a DLL provided by DeltaTau. The ethernet cable is connected to a board labeled "DELTA TAU cPCI TURBO PMAC2 CPU". It also has a USB port (unused) and a serial port (unused).
Apart from some servo and stepper motor controllers, there seems to be other I/O in the same crate, analog and digital. I have to dig through a huge pile of docs and code before I know what it actually is and what the original program is doing with it.
Dirk
Rees, NP (Nick) wrote:
Dirk,
Which Delta Tau UMAC drivers are you using? The driver on the GSECARS
site http://www.gmca.aps.anl.gov/TPMAC2/ was initially developed for a
UMAC ethernet interface. It is an interpose interface for AsynIPPort.
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: 09 December 2008 14:05
To: tech-talk
Subject: DeltaTau UMAC ethernet access?
Hi all,
Is there a driver for the DeltaTau UMAC ethernet interface?
I could only find drivers for VME based or PCI based PMAC controllers but not for controllers (Turbo PMAC 2 CPU) connected via ethernet or USB. The protocol seems to be the same as for other DeltaTau controller types, only the data transfer layer is different (uses UDP). A typical case for asynOctet, I think.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
</FONT></DIV>
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
DeltaTau UMAC ethernet access? Dirk Zimoch
RE: DeltaTau UMAC ethernet access? Rees, NP (Nick)
Prev: RE: DeltaTau UMAC ethernet access? Mark Rivers
Next: Support for shell variables in the EPICS build system Remi Machet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
