1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ao record downloading error
To: [email protected]
Date: Wed, 17 Dec 2008 21:54:55 +0800
Hi, all
   There is a problem while downloading an "ao" record which is used for a
peripheral I/O device named "PSC", part of the downloading console is like this:
(OS is RTEMS, and EPICS version is 3.14.6)
   dbLoadRecords("../db/powersupply.db")
0x00000000 (0)
   iocInit()
Starting iocInit
###  EPICS IOC CORE built on Jan  9 2008
###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
filename="../recGbl.c" line number=88
Bad init_rec return value  PV: R4IBT04:CISet  ao: init_record
0x00000000 (0)
iocInit: All initialization complete
and contents of "R4IBT04:CISet" is as follows:
record(ao,"R4IBT04:CISet") {
		field(DESC, "analog output record")
		field(SCAN, "Passive")
		field(DTYP, "PSC")
		field(OUT, "#C1 S0 @SPT")
		field(PINI, "NO")
		field(PHAS, "0")
		field(EVNT, "0")
		field(DISV, "1")
		field(SDIS, "0.000000000000000e+00")
		field(DISS, "NO_ALARM")
		field(PRIO, "LOW")
		field(FLNK, "0.000000000000000e+00")
		field(OROC, "0.0000000e+00")
		field(DOL, "0.000000000000000e+00")
		field(OMSL, "supervisory")
		field(OIF, "Full")
		field(PREC, "3")
		field(LINR, "NO CONVERSION")
		field(EGUF, "0.0000000e+00")
		field(EGUL, "0.0000000e+00")
		field(EGU, "amps")
		field(ESLO, "0.0000000e+00")
		field(EOFF, "0.0000000e+00")
		field(ASLO, "1.525902e-04")
		field(AOFF, "-5.010000e+00")
		field(DRVH, "0.0000000e+00")
		field(DRVL, "0.0000000e+00")
		field(HOPR, "4.545455e+00")
		field(LOPR, "-4.545455e+00")
		field(HIHI, "5.000000e+00")
		field(LOLO, "-5.000000e+00")
		field(HIGH, "0.0000000e+00")
		field(LOW, "0.0000000e+00")
		field(HHSV, "NO_ALARM")
		field(LLSV, "NO_ALARM")
		field(HSV, "NO_ALARM")
		field(LSV, "NO_ALARM")
		field(HYST, "0.000000000000000e+00")
		field(ADEL, "0.000000000000000e+00")
		field(MDEL, "0.000000000000000e+00")
		field(SIOL, "0.000000000000000e+00")
		field(SIML, "0.000000000000000e+00")
		field(SIMS, "NO_ALARM")
		field(IVOA, "Continue normally")
		field(IVOV, "0.000000000000000e+00")}
any help is appreciated, thanks a lot!
Haoli Shi
Re: ao record downloading error Andrew Johnson
Prev: Re: Problems getting edm functional on NetBSD David Dudley
Next: Re: ao record downloading error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Question on signals with Linux Mark Rivers
