1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ao record downloading error
To: Shi HaoLi <[email protected]>
Cc: [email protected]
Date: Fri, 19 Dec 2008 14:25:54 -0600
On Friday 19 December 2008 02:57:29 Shi HaoLi wrote:
> Cexp>dbgf ("R4IBT04:CISet")
> DBR_DOUBLE:         0
> 0x00000000 (0)
> Cexp>dbtr("R4IBT04:CISet")
> ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 0
> filename="../recGbl.c" line number=88
> AOFF: -5.01         ASG:                ASLO: 1.525902e-04  BKPT: 0x00
> PV: R4IBT04:CISet  dbtr(dbProcess)
> DESC: analog output record              DISA: 0             DISP: 0
> DISS: NO_ALARM      DISV: 1             DOL:CONSTANT 0.000000000000000e+00
> DRVH: 0             DRVL: 0             DTYP: PSC           EGU: amps
> EGUF: 0             EGUL: 0             EOFF: 0             ESLO: 0
> EVNT: 0             FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0
> HIHI: 5             HOPR: 4.545455      HSV: NO_ALARM       HYST: 0
> INIT: 0             IVOA: Continue normally                 IVOV: 0
> LALM: 0             LBRK: 0             LCNT: 0             LINR: NO
> CONVERSION LLSV: NO_ALARM      LOLO: -5            LOPR: -4.545455     LOW:
> 0 LSV: NO_ALARM       MDEL: 0             MLST: 0             NAME:
> R4IBT04:CISet NSEV: NO_ALARM      NSTA: NO_ALARM      OIF: Full
> OMOD: 0 OMSL: supervisory   ORAW: 32833         ORBV: 1062          OROC: 0
> OUT:VME_IO #C1 S0 @SPT                  OVAL: 0             PACT: 0 PHAS: 0
>             PINI: NO            PREC: 3             PRIO: LOW PROC: 0
>       PUTF: 0             PVAL: 0             RBV: 1062 ROFF: 0
> RPRO: 0             RVAL: 32833         SCAN: Passive SDIS:CONSTANT
> 0.000000000000000e+00     SEVR: INVALID
> SIML:CONSTANT 0.000000000000000e+00     SIMM: NO            SIMS: NO_ALARM
> SIOL:CONSTANT 0.000000000000000e+00     STAT: READ          TPRO: 0
> TSE: 0              TSEL:CONSTANT       UDF: 1              VAL: 0
> 0x00000000 (0)
> Cexp>dbpf ("R4IBT04:CISet", "2.0")
> 0xffffffff (-1)
> filename="../dbTest.c" line number=365
> dbPutField error
> I guess something is wrong when the record "R4IBT04:CISet" calls device
> support write_ao which calls driver support, I don't know how to solve it.
> thank you again!
The above errors are very similar to the previous one, in that I believe they
are caused by the PSC device support's write_ao() routine returning -1.  Both
your dbtr() and dbpf() commands cause the record to process resulting in the
device support being called; if write_ao() returns any non-zero value it will
be passed back up the call tree and eventually result in they messages that
you are seeing.  What that return value means is a question you'll have to
ask the person who wrote the device support.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
ao record downloading error Shi HaoLi
Re: ao record downloading error Andrew Johnson
Re: ao record downloading error Shi HaoLi
Prev: Re: ao record downloading error Shi HaoLi
Next: Units request for stringin records John Faucett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Firewire (IEEE 1394) support for areaDetector Pedersen, UK (Ulrik)
