1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PMAC IP and motor records
To: tech-talk <[email protected]>
Date: Tue, 13 Jan 2009 10:18:43 +0100
Hi all,
I am trying to set up a few motors on a PMAC system with ethernet connection. I have never worked with PMAC before and need some help.
I tried the tpmac package but I do not understand completely what I have to write in the startup script and how set up the motor records. I need access to 13 motors with the numbers 1,2,3,4,5,7,8,9,10,11,17,18,19.
Can someone send me an example startup script and an example motor record, please?
So far, I guessed from various bits of documentation:
drvAsynIPPortConfigure pmac xx.xx.xx.xx:1025
pmacAsynIPPortConfigure pmac 0
pmacAsynMotorCreate pmac 0 0 19
drvAsynMotorConfigure pmacmotor pmacAsynMotor 0 20
After pmacAsynMotorCreate, I get error messages like these:
Creating PMAC motor driver on port pmac, address 0: card: 0, naxes: 19
2009/01/13 10:06:18.004 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 10:06:18.666 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:18.882 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:19.182 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:25.801 Read/write error to PMAC card 0, axis 9 command I900=1. Status=1, Error=192.6.94.5:1025 timeout: Resource temporarily unavailable 2009/01/13 10:06:26.117 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:26.317 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:26.910 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:27.127 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:27.427 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:34.050 Read/write error to PMAC card 0, axis 14 command I1400=1. Status=1, Error=192.6.94.5:1025 timeout: Resource temporarily unavailable 2009/01/13 10:06:34.367 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:34.567 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:36.050 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:36.270 drvPmacGetAxisInitialStatus: not all status values returned 2009/01/13 10:06:42.269 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 10:06:42.370 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:42.570 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:42.870 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:43.270 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:43.770 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:50.523 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 10:06:50.624 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:50.824 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:51.124 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:51.526 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:52.028 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:52.751 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:53.452 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:54.252 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:55.153 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:56.153 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:57.153 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:58.153 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:06:59.153 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:05.694 pmac read pmacFlush failed - thisRead=0, eomReason=0, status=1 2009/01/13 10:07:05.794 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:05.994 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:06.294 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:06.694 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:07.194 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:07.794 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:08.494 pmac read pmacReadReady failed status=1,retval=02009/01/13 10:07:09.294 pmac read pmacReadReady failed status=1,retval=0
With only drvAsynIPPortConfigure and pmacAsynIPPortConfigure, I can get access to the asynOctet layer and get responses to strings like "M9", but only sometimes. Often, stopping the ioc brings the PMAC in a state where it does not respond any more. Only a power cycle of the PMAC help. Any idea what is wrong?
Some more questions:
Can the motor record read the encoder values from PMAC?
How can I use programs (homing an scanning procedures) on the PMAC?
How to access other values (analog and binary IO) on the PMAC?
Thanks in advance for any help
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: PMAC IP and motor records Rees, NP (Nick)
Prev: RE: EPICS asyn error message Rees, NP (Nick)
Next: webca can't connect to pvs? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS asyn error message Richard Pastrick
Next: RE: PMAC IP and motor records Rees, NP (Nick)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
