1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: webca can't connect to pvs?
To: "tech-talk" <[email protected]>
Date: Tue, 13 Jan 2009 17:34:46 +0800
hi,
  I want to use webca. After compiling the code and copy .so file to mozilla's plugin directory. I use firefox to open the test.html coming with webca package. seems the plugin works, while I can't get the pv's value.
  Ps, I can use caget to acqure the ai001's value first, then start the firefox from the shell to visit that test.html file.
  Any help is appreciated. thanks a lot.
following is the webpage's context:
EPICS Channel Access Plug-in Test
This page contains a test case which test the implementation of EPICS Channel Access Plug-in Test
Test 	Result
Get EPICSPlugin scriptable instance 	PASSED
EPICSPlugin.version 	PASSED
EPICSPlugin.epicsVersion 	PASSED
Connection monitoring 	(unknown)
Connection monitoring (second) 	(unknown)
Connection monitoring (on connected) 	(unknown)
Connection monitoring (non-existant record) 	PASSED
Connection monitoring (second, non-existant record) 	PASSED
Get request (no blocking test) 	PASSED
- value 	(unknown)
- status 	(unknown)
- severity 	(unknown)
- timestamp 	(unknown)
Get string (enum) scalar 	(unknown)
Get double array 	(unknown)
Get long array 	(unknown)
Get string array 	(unknown)
Put request (no blocking test) 	PASSED
Put double scalar 	(unknown)
Put long scalar 	(unknown)
Put string (enum) scalar 	(unknown)
Put double array 	(unknown)
Put long array 	(unknown)
Put string array 	(unknown)
Put without callback 	PASSED
Put with wrong data 	(unknown)
Monitor request (no blocking test) 	PASSED
- value 	(unknown)
- status 	(unknown)
Monitor array 	(unknown)
Monitor destruction 	(unknown)
Best regards
Geyang  2009-01-13
Re: webca can't connect to pvs? Tom Pelaia
RE: webca can't connect to pvs? Purcell, J. David
Prev: PMAC IP and motor records Dirk Zimoch
Next: RE: PMAC IP and motor records Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PMAC IP and motor records Dirk Zimoch
Next: Re: webca can't connect to pvs? Tom Pelaia
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
