Benjamin Franksen wrote:
Our idea for an efficient implementation is based on the observation
that in a typical EPICS database there are only very few fields per
record that actually receive dbPuts (or get updated directly from
within base). Only for these fields is it necessary to provide storage
for the time of the last update. This storage will be allocated on
demand; each record must maintain a (typically very short) list of
(field index, timestamp) pairs; let us call it the 'field update list'
or short 'update list'. When reading the timestamp for a field, first
search the update list and use the contained stamp if one is found,
otherwise use the TIME field of the record.
How does that implement (b) ? If a field is never updated,
shouldn't that field then report the time when iocInit() was
executed?
Ah, a good objection. It looks as if we need to distinguish between fields
that have
i) never been changed (timestamp = iocInit time)
only if PINI=Yes?
ii) last been updated by record support (timestamp = record's TIME field)
iii) last been updated via dbPut or from base (timestamp = see update list)
Maren
- Re: wrong timestamps in monitors Benjamin Franksen
- wrong timestamps in monitors Benjamin Franksen
- Re: wrong timestamps in monitors Till Straumann
EPICS Codeathon 2009 at Brookhaven Andrew Johnson
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
