Subject: |
Re: caget with an array of space-containing strings |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 27 Feb 2009 01:23:17 +0100 |
In general I would second Andrew's statement. Looping over CA command
line tool calls would be bad behaviour in terms of CA.
I have to admit, though, that arrays of strings with embedded spaces
break one of the command line tools' underlying ideas: caput understands
the caget return value of the same PV.
So, an command line option to change the separator could be a feasible
solution, or quoting those strings, or both. Any preferences?
Ralph
- Re: caget with an array of space-containing strings J. Lewis Muir
- Re: caget with an array of space-containing strings Andrew Johnson
- caget with an array of space-containing strings Carl Schumann
Re: caget with an array of space-containing strings Matthieu Bec
<2009>
2025
<2009>
2025
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
