1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget with an array of space-containing strings
To: Carl Schumann <[email protected]>
Cc: [email protected]
Date: Thu, 26 Feb 2009 22:51:36 -0300
Hi Carl,
if your string holds any kind of valuable information, it might be best to break it down as soon as you get in your ioc - other processes will make sense of it without having to re-parse the information, including caget. xml enthusiasts please destroy my argument but I found strings more like a convenient SMS. Looking at your output, if you're debugging something lower level consider a regexp (scripted, or awk if you want command line) will probably do the job.
Matthieu
Carl Schumann wrote:
I am using the command-line caget with an array of space-containing strings. Apparently caget uses spaces to separate array elements. A space separator causes some difficultly in this case because the elements themselves contains spaces. For example, ...
clx39:~ $ caget -# 1 ADC00.RNGS
ADC00.RNGS                     50, 10k: -10->0
clx39:~ $ caget ADC00.RNGS
ADC00.RNGS 9 50, 10k: -10->0 50, 10k: +-5 50, 10k: 0->10 50: -6->0, 10k: -5->0 50: +-3, 10k: +-2.5 50, 10k: 0->5 50: -5->0, 10k: -2->0 50: +-2.5, 10k: +-1 50: 0->5, 10k: 0->2
clx39:~ $
One can ask for specific elements as I have done, but that is a little bit inconvenient. Any suggestions?
Carl Schumann
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
caget with an array of space-containing strings Carl Schumann
Prev: Re: caget with an array of space-containing strings Ralph Lange
Next: Record Initialization Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget with an array of space-containing strings Andrew Johnson
Next: Re: caget with an array of space-containing strings Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
