1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget with an array of space-containing strings
To: tech-talk Techtalk <[email protected]>
Date: Fri, 27 Feb 2009 10:11:58 -0600
I'd like to suggest that there also be an option to caget/caput that makes them produce/accept 'comma separated value' strings compatible with a spreadsheet.
I suspect that this might work acceptably with the shell, too, if you temporarily did IFS="," and then did a 'set' on the caget output.
On Feb 27, 2009, at 10:01 AM, Andrew Johnson wrote:
On Thursday 26 February 2009 18:23:17 Ralph Lange wrote:
I have to admit, though, that arrays of strings with embedded spaces
break one of the command line tools' underlying ideas: caput understands
the caget return value of the same PV.
So, an command line option to change the separator could be a feasible
solution, or quoting those strings, or both. Any preferences?
Carl Schumann also wrote (privately):
Even as human I have trouble parsing the result.  The PV is not
mine and so I don't really understand the strings I am looking at to
being with. The lack of an obvious separator complicates matters further.
I agree that your particular example was pretty much impossible to read, so we
should fix the tools.
How about we change ca{get,put,monitor} so that if they're printing string values (and ENUM choice strings) that contain spaces or other characters that
need escaping for the shell, they enclose them in double-quotes?
I guess they should also escape control characters, and the rule should probably apply to PV names as well. Maybe we need an option to turn this on
though?
A good Codeathon job, if you need one Ralph...
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
caget with an array of space-containing strings Carl Schumann
Re: caget with an array of space-containing strings J. Lewis Muir
Re: caget with an array of space-containing strings Ralph Lange
Re: caget with an array of space-containing strings Andrew Johnson
Prev: Re: caget with an array of space-containing strings Andrew Johnson
Next: EPICS drivers or an EPICS interface to lantronix Embedded Device server communicating over TCP/IP Sandeep Babel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: caget with an array of space-containing strings Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
