OK. Thanks for the information.
Bill Lavender
On Mon, Mar 23, 2009 at 03:38:36PM -0500, Eric Norum wrote:
> This change is in the CVS repository for the R3.14 branch and the CVS
> head.
> On Mar 23, 2009, at 3:05 PM, Bill Lavender wrote:
>> I have encountered a minor problem with EPICS base 3.14.10 on MacOS X
>> systems that I would like to report. In my situation, I have a Python
>> module coded in C that invokes a library of mine, which in turn links
>> to the EPICS libCom and libca libraries. The symptom of the problem
>> is
>> that when I try to import the Python module, I get an error like this:
>> ImportError: dlopen(./MpPrivate.so, 2): Symbol not found: _environ
>> Referenced from: /opt/epics/base-3.14.10/lib/darwin-x86/libCom.
>> 3.14.10.dylib
>> Expected in: flat namespace
>> This is on a computer running MacOS X 10.5 (Leopard).
>> The source of the problem is that MacOS X defines the symbol 'environ'
>> in some situations, but not all situations. I have found a variety of
>> forum posts and mailing list entries on the Internet that describe the
>> problem and how to fix it. The message
>> http://lists.apple.com/archives/xcode-users/2004/jan/msg00230.html
>> gives a particularly clear description of the issue and I quote part
>> of
>> it here:
>>> _environ is defined in /usr/lib/crt1.o, which is only linked into
>>> executables. The corresponding file for dylibs (which frameworks
>>> use) is
>>> /usr/lib/dylib1.o and doesn't define _environ. Annoying as that is,
>>> it's
>>> correct because otherwise your library's _environ would be different
>>> from
>>> the _environ of the executable that loaded it.
>>> If you want to use _environ in a library on Mac OS X, you should use
>>> *_NSGetEnviron() instead. It's defined in /usr/include/crt_externs.h.
>>> Hope this helps,
>>> Eric
>> As far as I can tell, the only place in EPICS base that uses the
>> 'environ'
>> symbol is the function epicsEnvShow() in "src/libCom/osi/os/default/
>> osdEnv.c"
>> I have created a modified version of this function that looks like
>> this
>> #if defined(__APPLE__)
>> # include <crt_externs.h>
>> # define environ (*_NSGetEnviron())
>> #endif
>> * Show the value of the specified, or all, environment variables
>> epicsShareFunc void epicsShareAPI epicsEnvShow (const char *name)
>> if (name == NULL) {
>> #if !defined(__APPLE__)
>> extern char **environ;
>> #endif
>> char **sp;
>> for (sp = environ ; (sp != NULL) && (*sp != NULL) ; sp++)
>> printf ("%s\n", *sp);
>> else {
>> const char *cp = getenv (name);
>> if (cp == NULL)
>> printf ("%s is not an environment variable.\n", name);
>> else
>> printf ("%s=%s\n", name, cp);
>> I haven't actually tested the modified version of the function, since I
>> do not use epicsEnvShow() for anything, but this change is enough to
>> get
>> my Python module to load successfully without any missing symbols.
>> Hope this helps,
>> Bill Lavender
> Eric Norum <[email protected]>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
- environ symbol on MacOS X with EPICS base 3.14.10 Bill Lavender
- Re: environ symbol on MacOS X with EPICS base 3.14.10 Eric Norum
RE: Motor problems(RBV can't update itself) Xu, Huijuan
<2009>
JCA2 vs CAJ? GaryCarr
<2009>
