Hello all,
I have noticed oddities with my longout records.
Particularly when I use the soft Channel record.
record(longout, "myLO") {
field(VAL ,"100")
field(SCAN, "Passive")
field(DTYP, "Soft Channel")
Now if I create a medm text entry attached to this PV, and attempt to
modify the PV, it updates but not as expected. For example, if I enter
the value 10, the PV is updated to -11100023 (or something like that)
I am using medm 3.1.1 compiled against EPICS 3.14.9.
I have other longout records which are not "Soft Channel".
They correctly update with the same medm widget.
Any idea?
Emmanuel
- RE: longout record issue Mark Rivers
- Re: longout record issue Dirk Zimoch
- Re: longout record issue Andrew Johnson
Report from the Second Annual EPICS Codeathon Andrew Johnson
<2009>
2025
<2009>
2025
