1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: longout record issue
To: "Emmanuel Mayssat" <[email protected]>, "epics" <[email protected]>
Date: Mon, 6 Apr 2009 21:34:02 -0500
I just created a database containing only the record in your message below, loaded it into an EPICS IOC on Linux, and created an medm screen to control and monitor it.  It worked fine.  I wrote the value 10 in the text entry widget, and 10 was displayed in the text monitor widget, as well as with the "dbpr" command at the iocsh prompt.
This is EPICS 3.14.10 and medm 3.1.2.2, but I really doubt if there was a problem with either the earlier version of EPICS or medm you are using.
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Mon 4/6/2009 7:37 PM
To: epics
Subject: longout record issue
Hello all,
I have noticed oddities with my longout records.
Particularly when I use the soft Channel record.
record(longout, "myLO") {
        field(VAL ,"100")
        field(SCAN, "Passive")
        field(DTYP, "Soft Channel")
Now if I create a medm text entry attached to this PV, and attempt to
modify the PV, it updates but not as expected. For example, if I enter
the value 10, the PV is updated to -11100023 (or something like that)
I am using medm 3.1.1 compiled against EPICS 3.14.9.
I have other longout records which are not "Soft Channel".
They correctly update with the same medm widget.
Any idea?
Emmanuel
longout record issue Emmanuel Mayssat
Prev: longout record issue Emmanuel Mayssat
Next: Re: longout record issue Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
